RO: Q5 3.0 TDI -245 HP - Body Vibration starting from 110-130 km/h
Old Jun 13, 2024 | 04:10 AM
cttq5's Avatar
Default RO: Q5 3.0 TDI -245 HP - Body Vibration starting from 110-130 km/h
Hello,
I have a problem on my Q5 2013-3.0 TDI 245 hp, body start vibration from 110-130 km/h special the back seat and then the wall car.
- all 4 axle driveshaft change
- central driveshaft change
-rear shock absorber change
==problem not solved
- mechanic guy check all the arms, bushing etc. ==good condition
i don't now what to doo next!!! (((
Someone have this problem????
Old Jun 13, 2024 | 04:29 AM
stash64's Avatar
Did the mechanic check the rear subframe? It can be weakened by corrosion. And were the wheel bearings checked/replaced?
Old Jun 13, 2024 | 05:03 AM
cttq5's Avatar
Indeed the subframe is full of rust, the mechanic check all the bushing and whell bearings(no noise), but someone did say say that can cause vibration even if don't make noise.
Old Jun 13, 2024 | 08:42 AM
spijun's Avatar
Tech Guru
Tech Guru
Are all the wheels properly balanced, I had a similar problem a long time ago, the wheel balancing machine was not working properly
Old Jun 13, 2024 | 09:13 AM
stash64's Avatar
Or could have lost some wheel weights. That would be a nice easy fix.
Old Jun 30, 2024 | 06:19 AM
AudiAllTheWay's Avatar
Community Builder
Pot hole damaged tires and or bent rims can also cause this symptom. Some pot hole damaged tires visually show nothing to see but if the belts are dented from impacts then the solution is to replace tires.
Can try rotating the wheels and if a wobbly one lands on the front then you also get steering wheel vibrations when the oscillations setup at speed.
You can try lifting vehicle and spinning tires by hand while watching inside rim edge, sidewalls and tire contact surface for wobbly anomalies, otherwise a pro wheel shop Hunter Road Force test machine or equivalent will definitely pickup wheel issues.
grannat
10
Jan 14, 2006 12:01 PM
ReeseR
9
Jan 8, 2003 02:03 PM
GlennH
Audi A3 / S3 / RS 3
Dec 21, 2002 04:07 PM
nbennett_uk
Audi A3 / S3 / RS 3
Oct 29, 2002 04:44 AM
