When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
So I have a 06 a8l quattro 4.2l v8 I have continental control contacts 255/40zr19 100y idk what to inflate them to door jam says 38/ 36 but tires say max of 51 I have them at about 40 rn I'm not sire what should be optimal pressure
Bosco, welcome to Audiworld! Do you have the Owner's Manual? That will have a section toward the rear of the booklet that covers wheels/tires. There you will find the NORMAL load inflation pressures and the MAX load pressures for the various size wheels fitted to the car at the factory.
Inflate them per the pressures shown on the door jamb sticker.
Max. inflation pressure shown on the tire is a safety limit to not inflate beyond, never a recommended operating pressure.
the door jam is for 100h i have 100y xl on it now so
the owners manual says for 255/40r19 100y xl is 33 front max and min and back is min load 30 max 33 just seems low
You’re overthinking it, but it’s up to you which pressures to choose. Recommend by Audi is 33 front, 30 rear for normal loads (y or h designation, isn’t important in this respect), and that’s what I run mine at, and offers the best ride/handling balance.
What’s in the door jamb (aka the Ford Explorer Bridgestone tyre failure CYA sticker) is the maximum recommended pressure by Audi.
