Replacing headlight bulbs (07 S8 D3)
Old Jun 17, 2024 | 10:28 AM
AndyPfucterpus's Avatar
Default Replacing headlight bulbs (07 S8 D3)
Not sure if the search function is broken right now or what but I tried searching first and everything I typed in came back with no results.
All I'm trying to do is replace the headlight bulbs on my 2007 Audi S8 and I'm not sure where to begin. Does anyone have a walk through or some pics or a step by step process?
I started by removing two screws on the driver side, since that's the side that's out right now but now I'm lost on what to do next.
Old Jun 17, 2024 | 10:42 AM
As you can see, I don't have much space to work with.
Driver's side with the top two screws removed
Just showing the tight wheel fitment, as I've read some bits about having to remove some wheel liner to gain access?
Old Jun 17, 2024 | 11:44 AM
dvs_dave's Avatar
AudiWorld Wiseguy
Wheel off, wheel liner out, airbox out, access the back of the headlight through there.
Old Jun 20, 2024 | 01:33 PM
Definitely not the answer I was hoping for but it's a solution! Thank you!
Old Jun 24, 2024 | 05:13 PM
sswari's Avatar
Better than the alternative, Pull bumper cover, pull headlight(Hope you don't misalign, this would take about 3 x as long.
Old Jun 30, 2024 | 05:35 PM
MP4.2+6.0's Avatar
Tech Guru
+1. Good to learn on the car. Buy extra plastic push pins (aka rivets) from dealer or maybe an indy first. Up to about 5 per side/liner. You will break some, lose other center punch pins, and find yet more too distorted. Or, some not there from prior work. Once you do it firat time, pretty easy. Need to know for drivers airbox pull (if like W12), upper control arms and a variety of other things where you come in from sides.
blancotenerife
A4 (B8 Platform) Discussion
Mar 24, 2021 02:26 PM
signut
Mar 7, 2015 08:27 AM
4CE FED NOGARO
A4 (B7 Platform) Discussion
Aug 25, 2009 04:40 PM
j0kr187
May 27, 2007 07:01 AM
port9201
10
Jun 5, 2005 02:57 PM
