Secondary Air injection system faults
in the passed my tech was able to confirm the pump was working (though he commented it may be running slow) and it past the smoke test he performed. Let off with let’s see if the problem gets worse so he can further trouble shoot.
what are some os the possible causes to impact banks 1-4? This is the first time I am seeing all 4 banks come up. In the past I’ve seen 1,2 and 3 at different times.
The secondary injection pump is down at the bottom pretty much below the right side headlight. You have to take the belly pan off and then find the pump. I just looked at the self study guide and you'll find the pump and the solenoid valve N112 that has the vacuum lines hooked up to it. There is a "goes in" and a "goes out", I bet the vacuum lines attached to one end is split, inspect it as far as you can.
The pump and valve assembly look like this:
https://www.audiworld.com/forums/a8-...p1411-3067616/
