MK: 2009 Q5, dsg problem, jerks or shuts down enigine when I stop or put in R or D
I have a problem with the transmission, but this only happens when the car is cold. After a couple of minutes driving and when it hits the working temperature it starts working normal.
Here is the problems I'm having while the engine is cold:
-when I try to put it in R or in D, the engine will either shut down or the car will jerk or jump.
-while driving, when I come to full stop it will either shut down or the car will jerk or jump.
-while driving, in a steady gear (for example 4 or 5) the car will jerk constantly.
-also, when in D and in stop, I can see that the gearbox is putting more pressure to go than usual. And when I put it in N and then in D, sometimes it shut the engine and sometimes it jerks the car.
After a couple of minutes (when engine hits the working temperature) all these problems go away.
Guy from the local car garage told me that they had similar problems, they change the clutch and fix the problem. But that car had problems all the time, mine only when is cold.
Also, from a different place, they had a similar problem, but the transmission had problems when it gets hot, opposite to mine. They change the clutch first, it didn't fix the problem, after that they replace mechatronics and fix the problem.
Did anybody had a similar experience, I don't know what to do, this are all very expensive for me.
Thanks.
Does anybody have an idea what is wrong or has a similar problem?
Thanks.
