Driver's window replacement
Old Jul 19, 2024 | 02:29 AM
Curumo's Avatar
Default Driver's window replacement
I have to replace front door side window, driver's side. Can anyone point me into the right direction where can I find some know how on how to do it? Any YT links/tutorials greatly appreciated.
Old Jul 19, 2024 | 07:40 AM
simplesez's Avatar
I'll let you in on a little secret. You can learn a lot by going to the junkyard and practicing on a car there. You'll be able to find that front door window there. You don't have to be gentle with the panel on the junkyard car so when you miss a bolt or screw and tug hard it's no big deal.
Almost all cars have the same door construction. The panel is held on by a handful of screws that are mostly hidden. Once removed pull up slightly and it will pop out of track on the top. Then disconnect the wire harnesses. The door handle can differ but there is usually an easily removable cable.
Now you have access to the window track. The window is connected to the track at the bottom. Disconnect at the bottom and pull out.
The challenge at the junkyard is the window is rolled up, there is no battery, and you want the window down. But you can pull the panel there and see how to access the window track bolts. Just a suggestion.
here is one for the Q7. it will not be much different from the Q5
yepodm
Aug 11, 2022 09:40 AM
UrS4boy
Audi Original "S" Cars
Jun 11, 2013 08:03 AM
MKLW
Oct 31, 2011 01:39 PM
Dimi (A6 2.7T)
Jul 6, 2007 06:50 PM
ondo
Jun 24, 2002 10:08 AM
