2014 Front Parking Sensors Detection reversed
I assume this is an easy fix and just wanted to see if anyone else encountered this or knows what the issue is.
Thanks!
outer right, G252, blue/red wire, bumper harness plug pin 5 of 6
inner right, G253, blue/white wire, bumper harness plug pin 4 of 6
inner left, G254, blue/yellow wire, bumper harness plug pin 2 of 6
outer left, G255, blue/violet wire, bumper harness plug pin 3 of 6
pin 1, black/yellow, is the power to all the sensors; pin 6, brown/white, is the ground for all the sensors. Also notice, it's not a direct 5/4/3/2 flip flop order. If they inverted the order, you'd end up with the right outer sensor reporting as the left inner and such.
I don't have a B8.5 vehicle (A4/A5/Q5) so can't see if the J519 or OPS has any switchable bits or settings for flipping left vs right.
