MIL & EPC Lights - ROUGH idle/accel @ low RPM - 2013 Q5 2.0T - VAG codes
I had an appointment to get to, so I decide to drive it. Idle was/is extremely rough. Acceleration from stop is extremely sluggish and jerky - until the RPMs get up >2k. On my 5 mile mostly residential drive I discovered symptoms diminished to the point of not being noticeable as RPMs increased. So then I switched to tiptronic and held RPMs in the 3-4k range, and basically drove as normal otherwise - and you would think the car was fine until I had to slow down to start/stop.
I pulled the codes and have 4 Engine Faults found:
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [11101101] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 272793 km
Date: 2024.07.20
Time: 14:41:50
Engine RPM: 2345.00 /min
Normed load value: 59.2 %
Vehicle speed: 85 km/h
Coolant temperature: 94 °C
Intake air temperature: 48 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.805 V
Unlearning counter according OBD: 40
Mean injection time: 4.213 ms
Engine operating condition: Part throttle
Engine operating condition-Test_Program_Channel 87: 6
10591 - Cylinder 1
P0301 00 [11101101] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 272793 km
Date: 2024.07.20
Time: 14:41:50
VCDS
Diagnostic Trouble Code Report
Control Module Part Number: 8R1 907 115 B
Page 2
10205 - Cylinder Disabling
P130A 00 [00100100] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 272794 km
Date: 2024.07.20
Time: 14:42:41
Engine RPM: 1621.50 /min
Normed load value: 11.4 %
Vehicle speed: 11 km/h
Coolant temperature: 90 °C
Intake air temperature: 74 °C
Voltage terminal 30: 13.499 V
Mean injection time: 1.612 ms
A/C compressor: load current: act. value: -199.50 A
Torque request: A/C compressor: 793.6 Nm
4105 - Bank 1; System too Lean at Idle
P2187 00 [01100000] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 271630 km
Date: 2024.06.23
Time: 17:33:24
VCDS
Page 3
Engine RPM: 806.50 /min
Normed load value: 31.0 %
Vehicle speed: 0 km/h
Coolant temperature: 96 °C
Intake air temperature: 41 °C
Voltage terminal 30: 12.910 V
Unlearning counter according OBD: 2
Mean injection time: 2.804 ms
Engine operating condition: Idle
Engine operating condition-Test_Program_Channel 87: 5
Thanks in advance for any ideas!
No 4 plug after 20K, which was the misfire, #3 for comparison
which was fine:
The plugs and coils I ordered just arrived, so I'm going to give those a go. Fingers crossed that's it.
I just finished pulling all the plugs/coils. Plug #1 was the worst (shot), as expected - but all the plugs were pretty bad. I've previously run plugs a lot longer, I guess with age the engine it's just leaving more carbon/build up. Probably doesn't help that I also just did a LiquiMoly fuel system cleaner about 1k miles ago. The coils themselves all seemed fine.
I attached a picture of all the plugs (#1 by itself, and then #1-4 from left to right - with a new plug there just for comparison).
I had previously purchased the plug/coil pack from FCP, so I guess I'll give their Lifetime Warranty (credit) a try.
Thanks again for all the help!
