Anybody know how to pop the hood when the cable snaps?
Old Jul 23, 2024 | 07:02 PM
Bosco1019's Avatar
Default Anybody know how to pop the hood when the cable snaps?
My hood release cable snapped today and my cowel drains are clogged does anybody know how to get the hood open. After the cable has snapped ..
Old Jul 24, 2024 | 05:59 AM
the green amigo's Avatar
Sawzall is your friend
Old Jul 24, 2024 | 07:32 AM
JohnnyJ's Avatar
I asked Gemini (https://gemini.google.com/app):
How to Open a Hood with a Broken Release Cable
Disclaimer: This can be a tricky situation. If you're uncomfortable or unsure about any of these steps, it's best to call a professional roadside assistance service.
Understanding the Risk
Before you start, it's important to know that working on a car with the hood closed can be dangerous. Be cautious and take your time.
Tools You Might Need:
  • A strong flashlight
  • A sturdy metal rod or coat hanger
  • A pair of pliers
  • Gloves
Steps to Try:
  1. Locate the Hood Latch:
    • Use the flashlight to find the hood latch. It's usually located near the center of the hood, behind the grille.
  2. Access the Latch:
    • You may be able to reach the latch through the grille or by removing some plastic covers. Be careful not to damage anything.
  3. Manipulate the Latch:
    • Use the metal rod or coat hanger to try and reach the latch. You might need to bend the rod into a hook shape to help you grab the latch.
    • Once you've hooked the latch, gently pull it towards you. This should release the hood.
  4. Check for Obstructions:
    • If the hood doesn't open, there might be an obstruction. Check for any ice, debris, or other objects that could be preventing the hood from lifting.
Additional Tips:
  • Safety First: Wear gloves to protect your hands from sharp edges.
  • Patience is Key: This process can be frustrating, so take your time and be careful.
  • Consider Professional Help: If you're unable to open the hood yourself, call a roadside assistance service or a mechanic.
Important: If you manage to open the hood, be sure to fix the broken release cable as soon as possible.
Regarding the clogged cowl drains: This is a separate issue that will need to be addressed once you can access the engine compartment. You can often clear them with compressed air or a gentle water flush.
Old Aug 2, 2024 | 04:47 PM
Opustm's Avatar
It depends on where it broke. If it broke in the most common place at the junction box (pull cable connects to the 2 his latch cables) then add mentioned you pop the driver's side tire off, remove the inner liner and snake your hand up between the abs module and engine. I have used a wire coat hanger or a bungie cord.
IF it popped off at the actual latch you'll be cutting a hood, to cut the catch pin.... Ask me how I know
Old Aug 3, 2024 | 11:47 PM
No need to take such drastic measures. Get the longest sawzell blade you can, slide between grille and hood and cut the latch from underneath. Place some protection on the edge of the hood to minimize damage. If you are precise and very careful you can get away with only some touch up paint work.
Old Aug 12, 2024 | 01:47 PM
Christian A's Avatar
Did it break from inside the car? There’s 2 ways it usually breaks 1 is from black junction box under hood, and the other is from junction box to one or both latches.
if it breaks from inside car just pull of drivers side wheel liner and wil long pliers pull the back
junction box really yards towards back of the car.
If it’s the latter you have to cut, I used a hand saw with a boroscope. Took long but was safer.
Old Aug 26, 2024 | 02:29 AM
Shkretoff's Avatar
Just cut the latch between hood and plastic with a blade for metal cutting. Put something on the blade, so it does not scratch the hood. New latch is cheap. Cable probably snapped in the junction box.
Old Aug 28, 2024 | 07:38 AM
Chimney's Avatar
I bought a used 2007 D3 Quattro, and sure enough both the left and right-side latches had been cut with sawzall. The hood had a wrinkle/curl across the center when one latch was cut and too much force was exerted to lift the hood while accessing the opposite latch. After closing the hood over the course of months, the wrinkle/curl vanished from the hood.
 Pouria Savadkouei
 Michael S. Palmer
High Speed S4
16
Mar 16, 2006 04:15 PM
bahb
May 19, 2003 06:53 AM
