Q5 TDI Coolant issues
It's not always going to fail but if it does, the labor will take you a day or so.. The other issue I've had with my Q5 TDI is an AdBlue sensor failure, but it's been pretty solid otherwise.
1. EGR coolers can leak internally, this allows coolant to be sucked into the intake, and results in excessive steam/smoke from the tailpipes and coolant loss.
2. The plastic valve in the valley leaks, or cracks, resulting in coolant loss.
3. Coolant leaks from old o-rings at the oil cooler, and any other locations and plastic parts. (Replace that crap with billet alloy ones.)
4. Start up timing chain rattle. Mine only rattles sometimes, and not for more than 3 seconds. Usually when starting the engine warm, and as the oil has more than 3000 miles on it.
In my opinion, the second gen TDI is excellent. Never use the auto stop/start feature, it just wears out your engine from lots of no oil pressure starts. Delete the filters/cats ASAP. Same with the EGR. Good tune and you get 37mpg, over 300hp, nearly 500tq and change the transmission fluid and filter every 80k. New fuel filter at that same time. Cheap insurance and better performance.
Darkside makes the best downpipes I've seen, SusTDI makes an excellent EGR/Valve/plastic fitting delete kit using billet fittings, quality hoses/clamps etc. No more points of failure, or clogging up your intake with carbon from the EGR.
Another bonus is you can run whatever diesel oil you want, nothing to get clogged up, no DPF/Def B/S.
