cv axle replacement
Old Jul 29, 2024 | 09:01 AM
dannymk2's Avatar
Default cv axle replacement
what is the preferred brand of replacement cv axles? Is GKN the go to or is raxles better? also, i know the axle nut is a stretch bold and needs to be changed, but what about the 6 triple square bolts at the transmission? do those need to be changed as well?
Old Jul 29, 2024 | 09:18 AM
SMac770's Avatar
Community Builder
Community Influencer
Audi does quote the inner flange bolts as replace if removed, though I didn't for mine. They are just a torque spec, not torque+angle, but TTY (torque to yield) bolts can come with whatever manner of fastening spec. But they really aren't that expensive.
Used OE has been my preference. If you can handle the downtime to let raxles rebuild yours, that would likely be next best. But then GKN is the OEM.
Old Jul 29, 2024 | 09:35 AM
dannymk2's Avatar
i assumed raxles are rebuilt oe since they need your axle core back. id rather not have the car on stands for 2 weeks waiting on an axle. buying the gkn is a little cheaper and would allow me to keep my old axle to rebuild later if need be, but if the raxles are significantly better, i think thats the route i would go. just wondering what the general consensus is on that.
Old Jul 29, 2024 | 02:43 PM
SMac770's Avatar
Community Builder
There's been threads about raxles and GKN and such between the various B8 forums, here and audizine, probably also elsewhere. Searching for raxle and GKN among the B8 A4, B8 S4, B8 A5/S5, and B8 Q5 forums should find those threads.
Old Jul 29, 2024 | 04:46 PM
AudiAllTheWay's Avatar
Community Builder
I rebuild original axles using new boots with OE GKN CV Joints if a joint has failed. By the time a boot fails which left undetected will cause a joint to fail, I like to at least replace upper control arms at the same time. Saves time and money in the long run and avoids repeat work in the near future.
Be sure to look up all part numbers specific to your vehicle
arU4ic
Oct 2, 2011 07:04 AM
kentcranes
Feb 1, 2010 09:00 AM
Jon-1.8t
Aug 20, 2006 07:03 AM
OCDaudi90q
Aug 31, 2005 08:04 PM
ChuckDee
Jan 25, 2005 01:44 PM
