P052E is not in 2013 Audi Q5 Quick Reference Specification Book
Old Jul 29, 2024 | 09:21 PM
thomascgty's Avatar
Default P052E is not in 2013 Audi Q5 Quick Reference Specification Book
2013 Audi Q5 3.0T Premium Plus
Recent Changes: PCV valve replaced, water pump replaced, thermostat replaced, vacuum hoses replaced.
Resolved Issues: Coolant leaking into an unknown location
Unresolved Issues: Excessive engine oil usage, ~700 miles for ~2quarts
Issue Description: No CEL. My cheap OBDII scanner shows the following.
  • P052E00 PCV Regulator Valve Performance.
  • P045600 EVAP Emission control Sys. (very small Leak), Leak Detected
Book only shows the following DTC for engine code CTUC.
  • P052A (Intake (A) Camshaft Position Actuator Circuit / (Bank 1) | Difference between target position and actual position > 12.0°CRK
  • P052C (Intake (A) Camshaft Position Actuator Circuit / (Bank 1) | Adjustment angle difference > 10° CA • Number of checks 2
Are those two the same as the P052E?
I have read some posts and Web information P045600 may be the fuel cap needing replacement.
Are the 3 small tubes on the middle connected on the correct ports?
Are those two supposed two be zip tied? Or did I got bamboozled? Does it needs to be a metal clip like the other ones?
Thank you for any assistance on this.
Old Jul 30, 2024 | 05:14 AM
SMac770's Avatar
Community Builder
Community Influencer
There doesn't seem to be any images of 8R0 201 991 AH, the hose from the EVAP vapors hard line to the N80 EVAP purge valve. But yes, it's unlikely Audi factory used zip ties. AH was replaced by AJ. We see an image of rev AJ here: https://www.audipartsstore.com/oem-p...se-8r0201991aj The parts catalog denotes the hose pieces are secured to the middle expansion chamber by N 906 867 01 (14x12). And the hose ends' connections to the N80 purge valve and to the vapor hard line are secured by N 909 865 01 or N 910 203 01 (14.5x12).
https://www.ecstuning.com/b-genuine-...ach/n90686701/
https://www.ecstuning.com/b-genuine-...ach/n90986501/
https://www.ecstuning.com/b-genuine-...lip/n91020301/
None of those are one-time-use Oetiker clamps, so not sure why they wouldn't still be in place.
P0456 says only what it says. When it tests the fuel tank for leaks, it detects the pressure reduce at a "very small leak" rate. Where it's leaking is anyone's guess, without a smoke test showing "oh, there it is". Fuel cap is not uncommon, and not "expensive" to just try.
P052E is not even documented by Continental (Simos owners), so who can guess how it actually triggers. P052E - Ross-Tech Wiki Google search "audi 3.0t p052e" brings up plenty of research for you. Could likely be related to the valve that the CTU engines added to the breather hose; you don't mention if you have a CGX or CTU engine. https://www.audizine.com/forum/showt...1#post14593245
Trase103
A4 (B8 Platform) Discussion
12
Sep 27, 2024 12:03 AM
supercal29
Q7 MK 1 Discussion
Mar 29, 2023 01:48 PM
Bubsxl
16
Mar 23, 2019 03:05 PM
AllanJJ
Sep 4, 2018 12:44 PM
dpulvino
May 17, 2009 07:58 AM
