ABS module
Looking for other ideas or possibilities.
My 08 A8L has the ESP/ABS/Parking brake light come on anywhere from 5-15 miles into driving. I lose speedometer/cruise etc. Trach works. Took it to an audio mechanic who told me to ditch the car because the ABS module is totally dead.
I'm going to clean the connector pins as soon as it's not 110+ outside.
My question is this, is the abs module something that can work but then fail as it gets hot or is it a it works or it doesn't.
Other than checking the contractor pins and wiring is there anything else to check as it seems odd that it works for 5-15 miles then throws codes and suits off Speedo.
Oh also it will throw a speed sensor engine code (save mechanic said it's because of the dead abs module not an actual speed sensor.
(I do not have a scanner to give me all the cool checks and codes everyone posts)
Any ideas or thoughts would be greatly appreciated.
Why would brake light switch cause the other systems to default to off? Little more info would be nice since you seem to know more than I.
The ABS electronic module can be removed from the valve block and sent away for repair easy enough. Plenty of module repair firms out there these days, and plenty of threads on here describing the process. Google is your friend.
Any companies to steer away from for rebuilding the middle or one that is the go to?
