How would you fix (or at least 'stop the bleeding' this rust spot?
I'm assuming there was a small chip in the paint or whatnot and it looks to now be rusting.
Thank you.
If you want to stop the rust first then apply something like Rust Converter, then apply the touch up paint.
If the original paint is bubbling then corrosion is creeping underneath around the opening. If so then you may want to first remove the bubbling paint around the edges, then apply Rust Converter, then apply touch up paint.
