2015 Q5 3.0T with PCV issue - looking for advice
Old Aug 14, 2024 | 09:19 AM
selli9ra's Avatar
Default 2015 Q5 3.0T with PCV issue - looking for advice
Hello, First time poster so will do my best to follow all protocol! I bought my Q5 new in 2015 and it has been my favorite car. Hate to part with it but I'm in a bit of a pickle. It has 105k miles on it, recently had to replace the daytime running light LED control module, not a week after that was done the car started to make a high pitched whistle/whining. The noise stops if I press on the gas or if the cruise control is actively putting power to the car (versus coasting or slowing down). Took it to an independent shop and the PCV codes came up. The shop informed me that the 2015 3.0T has an extended warranty (Number: AWA-19-03). So, I call my audi dealer (who the car has gone to for it's entire life including oil changes, regular servicing, etc.) and they inform me that my VIN is not covered (qualified via mileage, age, engine...just they are not including my VIN). Without getting into the weeds of production runs, recalls, etc. it is frustrating that Audi is sticking so hard and fast to their estimate (as that's exactly what it is) of the issue that this concerns. Anyways, Audi has told me to take it to the dealership to have them diagnose it and then they can submit a request to get an exception made and honor this extended warranty for my Q5. Thankfully the audi dealership is only going to charge me $100 for the diagnostics (keep in mind the independent shop did all of their work for free, including diagnostics). Once the audi dealership diagnoses it with the PCV codes covered by the warranty then a request to provide me with an exception can be made. Sorry, this is ranting a bit at times; will try to wrap it up quickly. If it is not covered then the cost of the dealership to fix it is $3,100 or the cost of the independent shop is $1,450. So, the advice I'm looking for is: 1. does anyone have any suggestions on increases my chances of having audi honor the extended warranty on my car? 2. if I have to pay to fix this - should I? My concern is that this car is worth @ $12k. So, $1.45k is over 10% of it's worth and given the age, mileage, and costs to fix audi vehicles is this something I should just walk away from? As much as I love my vehicle I'm not trying to turn this into a money pit on wheels. If this is something that is worth paying for and hopefully will be a long time before another big expense on this car are there other maintenance items that should be performed as long as this job is being done (my understanding is that the super charger comes off to fix the PCV issue). Apologies for writing a novel and thank you all in advance for any advice/guidance you can provide!
Specific codes: PO52E-00 (06262) and PO507-00 (20136) - PCV system failure
Old Aug 15, 2024 | 06:02 AM
stealths6's Avatar
I would go with your indie shop and just be done with it. I have exact same vehicle and it has been bulletproof. My 2 cents.
Old Aug 15, 2024 | 11:05 AM
A6Gary's Avatar
If you dump the Q5 w/o replacing the PCV, the cost for a replacement vehicle will obviously be more than the $1,450 repair cost. Since you have owned this Q5 from the beginning, fixing it would ensure that it will serve you well for a number of years/mileage. IMO, just fix it.
Old Aug 15, 2024 | 04:17 PM
AudiAllTheWay's Avatar
Community Builder
If you’re keeping it then what is the service history of the rest of the bits under the supercharger? For example consider replacing other wear items such as thermostat, waterpump, crossover coolant pipe, coolant temp sensor, etc while the supercharger is removed.
Old Feb 6, 2025 | 10:55 PM
AudiWorld2024's Avatar
Verified Member
My Q5 had the same problem. In the end, I attempted to fix the problem myself. During fixing I realised there are so many parts to be removed and reinstalled just for a little problem. That is why it would cost $$$$ for the job to be done by the proffessional. However, I am satisfied with DIY job because in addition to replacing the PCV valve, I had a chance to understand what beneat the Super Charger Unit, and I could do many other preventive maintenance as well eg: decarbonise the in-take manifold, cleaning the Super Charger Unit, changing the water pump, thermostat, surpentine belts and flushing the coolant. After the DIY, my car run very smooth and quite like new. But few day later, the same fault code came back even with the OEM new PCV valve installed. Having diagnossed the issue again, I found the fault was due to the "shutoff" solenoid valve (part No. 06E103207AP) which locates at the rear end of the Super Charge Unit. This solenoid valve is controlled by the engine ECU to close and open the fresh air supply to the PVC valve. I did an electrical test on the senloid valve I defined it is still functional and good. So why it does not work ? It got stuck-closed sometime when hot and the engine idling (low RPM) at trafic lights. To fix this issue is I protect the selenoid valve from heat with insulation material and heat shield. The problem went away for few years until now. This is a typical example of smart German engineering.
Old Feb 6, 2025 | 11:05 PM
Community Builder
What material did you use for a heat shield?
Can you post pics?
Old Feb 7, 2025 | 01:11 AM
Verified Member
I used the heat protection sleeve off a Volvo oxygen sensor harness. The material is glass-fibre with reflective silver lining. Cut the material to shape then wrap it arount the selenoid valve. Used thin copper wire to tie the heat shield in place. Sorry I don't have a picture.
kdr_audi
A4 (B9 Platform) Discussion
Mar 23, 2022 09:46 AM
viperboy
S6 / RS6 (C7 Platform) Discussion
Nov 18, 2020 09:42 AM
Tracy Rowland Gobert
Q7 MK 1 Discussion
Sep 19, 2020 12:48 PM
frostz
13
Apr 30, 2013 08:16 AM
geiswiz
12
Oct 31, 2002 04:05 AM
