Ride Height Sensor Design Guaranteed To Fail
Do you have a picture or location of these linkages?
Seems that the replacement Audi part has a different plastic link part snapped over the metal ball, so perhaps they had enough failures to change the materials in the part.
Based on the level of corrosion in the pics then you are likely not going to be happy with the condition of other chassis parts. For example have a closer look at the rear subframe.
If the plate is toast, then, the workshop manual doesn't even cover that directly. Appears it's secured by the upper link to subframe bolt head; they couldn't even bother to put it on the nut side. But that leads us to the statement "Due to the inaccessibility of the inner threaded connection -1-, the upper control arm can only be removed when the subframe has been removed." That "inner threaded connection -1-" is the bolt of interest. So getting that bolt out to replace the plate, a major task.
