AU: P001100 [000AEB] A Camshaft Position (Bank1)
I have replaced the solenoid and control modul, they work fine, but I still got this error code.
Tested with scan tool which are all functional as no issues.
But the error code still there.
P0011 for that engine means the measured angle is 6.8° to 8.0° more than it should be. If you log camshaft adjustment intake bank 1 specified vs actual, do you see this excessive difference between should be and is? When do you see this difference? Idling? Under load? At idle, the angle should be +28°. If you log those values during the VVT output test, you should see it run from +28° to -30° or so and then back.
Also, you have cleared all codes since the physical changes, yes? The existing P code would take a number of drive cycles to self clear, probably 40 or so. But you would just clear codes using the scan tool.
You are really champion.
The cam angel remained 28-29degress unchanged but required angel by ECU keeps changing.
The VVT soleniod works fine and VVT control works fine as well, I have tested with scan tool, I can hear the clicking noise.
But now, what's the problem? timing chain is definitely in time.
I heat to think it's the intake camshhaft problem, but how can I test it without remove all valve cover and timing gears?
It drives very smoothly and powerful.
can some gurus shars some lights
What are you getting for the adaptation value after the engine is up to temp and you've driven some and are currently idling?
In the last post, some terminologies. So the solenoid is the electro-magnet that extends the piston when energized, and allows the spring in the control valve to push the piston back in when de-energized. So you're saying the piston is stuck? Stuck extended or stuck retracted? If you run the N205 solenoid output test, do you have the piston moving in and out as the power is toggled?
N205 solenoid is the electrically connected round object mounted to the upper timing cover. The oil flow control valve is the thing in the intake cam, the thing with the "button" which the N205 piston actuates.
