PL: Oil consumption - should I be worried?
I have a thought that is bugging me recently... I bought a 2016 Q5 with CNCE 2.0TFSI engine. I decided to buy it knowing its a gen 3B engine, that should be safe from this whole oil doom. But recently some Youtube clips made me thinking if I did the right thing. I am asking cause some of those clips say gen 3 & 3B are safe, some say, that Audi corrected the pistons in 2013, but rings themselves were corrected in 2016-2017, thus even a 2016 engine wont be safe... My Q5 has 89.5k km, book says oil was replaced every 15k km. When I bought it, I replaced oil and filled it to exactly middle level between min and max on MMI. After ~200km I made with it, MMI dropped 1 notch down, what got me thinking... Nevertheless, this oil is only to clean crankcase a little and will be replaced after another 100-200km with an addition of some cleaning agent. After the replacement I plan to change oil every 9-10k km.
What do you folks think? Should I be worried or CNCE is already safe from oil consumption and I should look into a PCV?
I replace PCV’s every 100,000KM as preventative maintenance.
As for carbon buildup on piston rings, I know I want to use some kind of engine flush or rinsing agent with the next oil change, to try and get rid of as many stuff from inside the crankcase nad pistons/rings as possible. Also any tips on how I can clean it without taking whole engine apart to get to rings are greatly appreciated. Just bear in mind, that if you mention any specific cleaner from outside of Europe, I might not be able to aquire it...
Concerning other matter I am used to change oil every 10k km, 7500km seems a little bit extreme from my perspective... But on the other hand I am only used to VW's undestructible 1.9TDI... Honestly I have never driven gasoline engines, only diesel is present in my life so far.
BTW. Do you by any chance know what is the volume difference between min and max levels on MMI?
For the piston rings I am experimenting with a restore oil but I don't know if you can get it in Europe. I would not worry about it at this point if your oil consumption isn't that high. Most engine flush products won't have much effect on this engine. No need to worry in my opinion unless your consumption accelerates to very high usage. I have 135K+ miles on my 2014. Short oil changes will for sure help though, use an extractor which takes less than 15 mins.
