broke down and stuck please help
Old Sep 6, 2024 | 08:23 AM
anthony0920's Avatar
Default broke down and stuck please help
I am currently in the middle of relocating for work from california to alabama.. i came to lincoln county because it’s something i’ve wanted to see since i was a child.. ok story over.. but i am stranded on a mountain and quickly running out of resources.. everything was fine with the car , ran in the morning but died after a couple minutes… tried to restart and actually held on for a time.. now it will not turn over at all.. my vcds cable and program has taken a dumb but my obd11 was able to tell me a lean fuel code.. i tried to jump like i’ve read before but i can’t get a legitimate fuse or relay location and what i need to do exactly.. please help me and my boss ordered the primary right side pump but they delayed because of my address and name.. please help im in a bad spot
Old Sep 6, 2024 | 01:57 PM
PaulW's Avatar
I would try two things, first, fill the tank up in case one of the fuel pumps is out, it might help.
The other with the lean code would be to unplug the mass air fuel meter, it's between the air box and the intake. The car will then go into a pre determined air fuel ratio program. Best of luck!
JayTurk
A4 (B7 Platform) Discussion
Jan 1, 2024 06:27 AM
z31t70
Aug 23, 2010 01:28 PM
Typ89
12v V6 Discussion
Feb 5, 2010 06:05 PM
viks007
Aug 7, 2006 11:29 PM
mbox
11
Mar 31, 2006 06:49 PM
