AU: new build for 2014 AUDI Q5
Old Sep 18, 2024 | 09:57 PM
jasonfire's Avatar
Default AU: new build for 2014 AUDI Q5
Finished fixing 2009 Q5, driving very poweful and smoothly, the main thing, there's no issues, part from this bloody inspector, who gave ma a headache, I am still waiting for the solution from the VICROADS, which taked 2-4 weeks, it sucks!!!
SO I bought a 2014 low Kms, S-line 2.0L, TFSI again. with blown engine.
I will post some pics with very day, welcome to suggest or whatever, it's just for fun.
no coolant into the oil which is very good thing.
bloody AUDI, useing plastic ?
never seen the wheel stuck !!!
Old Sep 18, 2024 | 11:34 PM
jasonfire's Avatar
MORE PICS
NEED GOOD TOOLD TO ENJOY THE JOB
Old Sep 18, 2024 | 11:35 PM
jasonfire's Avatar
SO MUCH OIL IN THE COOLANT
Old Sep 19, 2024 | 05:54 AM
AudiAllTheWay's Avatar
Community Builder
Looks like a great project 👍
Having an aluminum rim seized onto the steel rotor hub is a common sign that the wheels have not been off in a long time and is usually combined with salted winter roads climate. I apply high quality penetrant around the circumference of the rim to rotor mating surface including the seam inside the lug holes, let soak, then rotate the rim and mule kick the tire as many times as needed to break it loose. No hammers and no damage to parts or painted surfaces.
Do you know what caused oil to enter the coolant system?
Old Sep 19, 2024 | 07:25 AM
jasonfire's Avatar
thx mate
good idea
don't really know what exactly happened to it, most likely due to water pump failure caused overheated. Heat gasket is leaking.
Old Sep 19, 2024 | 07:57 AM
Community Builder
Yeah overheating an engine is the worst. Some folks don’t realize the extensive damage caused by overheating which is the number one cause of leaking head gaskets, which means the aluminum head warped and possibly the block deck too.
Are you looking for a replacement engine?
Old Sep 19, 2024 | 08:01 AM
jasonfire's Avatar
hopefully i don't need to replace whole engine.
I already have a used head, wait till I open up engine to check.
Old Sep 20, 2024 | 06:58 PM
jasonfire's Avatar
more job and pics
very good condition, no scuff watever
two injectors
timging chains in good shap
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 21, 2024 | 12:36 AM
jasonfire's Avatar
Old Sep 21, 2024 | 12:37 AM
jasonfire's Avatar
Took me so long to clean those craps in coolant and engine block.
will check with straight edge to see the surfact in perfect flat.
