MMI sound problem
Old Sep 19, 2024 | 09:44 AM
zking's Avatar
Default MMI sound problem
Hello everyone, I have a problem with the audio system in my Audi,this is not b&o or bose system , I can only hear from the right rear speaker and when I try to transfer the audio through the screen to the left side, I can't hear anything, maybe you know what it could be, I thought about the Telephone box under the driver's seat . Thanks
Old Sep 20, 2024 | 02:45 PM
dvs_dave's Avatar
AudiWorld Wiseguy
If the amp may have failed or component protection on the amplifier has been activated. Have you changed anything recently?
Old Sep 21, 2024 | 01:03 AM
zking's Avatar
Hi, thanks for the reply , I did not change anything in the system
This is how I bought the car with this problem, when you turn on the system it makes a boom from the left side and then you only hear from the right rear speaker .
Old Sep 22, 2024 | 08:43 AM
dvs_dave's Avatar
AudiWorld Wiseguy
The amp was already dead, or in component protection before you bought it.
Old Sep 23, 2024 | 06:24 AM
zking's Avatar
I don't know, that's what the vcds show
Old Sep 23, 2024 | 06:30 AM
zking's Avatar
Old Sep 23, 2024 | 09:27 AM
dvs_dave's Avatar
AudiWorld Wiseguy
You’ll need to code the amp correctly first as that could be the problem. Although what the coding should should be I don’t know as it’s the base amp, not the Bose or B&O one. Maybe VAGCOM has coding guidelines to help figure it out?
You should also check the rear speaker wiring as it sees a fault there too. Maybe something is loose, disconnected, damaged, or maybe a bad speaker. Use conventional automotive diagnostic techniques to figure it out.
If none of the above fix it, then time to look at replacing the amp with a used one. Plenty on eBay. Part no. 4E0910223J, as you can see on your VAGCOM display.
Old Sep 23, 2024 | 10:35 AM
zking's Avatar
Thanks, i'll check and get back with an answer
 Pouria Savadkouei
 Michael S. Palmer
lneedham
Q5/SQ5 MKI (8R) Discussion
14
May 21, 2018 06:47 PM
AudiQ7Lady
Q7 MK 1 Discussion
Jan 8, 2015 05:47 AM
joseaudi
A6 (C7 Platform) Discussion
Sep 23, 2011 12:40 PM
Hellokitty123
Oct 4, 2010 04:39 PM
fraTTe (cdn)
Mar 25, 2000 05:28 AM
