Stuck Rings
Old Sep 19, 2024 | 12:37 PM
Lisa Dubs's Avatar
Default Stuck Rings
Hi all. I have a '12 Q5 2.0T with 198k. I had it in the shop and was told there is a loss of compression on two cylinders (after he de -carboned it). He said the rings were stuck, and blamed it on whoever did the piston/ring job over 120k+ miles before. My brother thought it might be carbon build up, and suggested putting marvel mystery oil in the cylinders and letting it set a few days. Then I was to remove fuel relay and spark plugs and crank the engine to blow the crap out of the cylinders. Problem is, it won't crank at all with the plugs and coils out. He's done this with other vehicles and the starter cranked the engine, but it's not working in the Q5. Any thoughts on why this is? Is there some safety thing that won't allow it? (Please don't tell me it won't start without plugs. I don't want it to start.) 😉 Thanks in advance! BTW, I'm in the middle of Wyoming. There are no dealerships here.
Old Sep 19, 2024 | 04:41 PM
AudiAllTheWay's Avatar
Community Builder
What is the marvel mystery oil that was used?
I would use a fluid extractor and remove any liquid from the cylinders. I would also blow out the cylinders with compressed air with a rag over the spark plug hole to remove the dregs. Then put it back together and start it. Ideally each cylinder should be filled to the spark plug hole with something like Berryman B12 and allowed to soak while each one is at TDC to ensure all valves are closed, as this also cleans the entire combustion chamber including the valve heads on a 2.0T.
Old Sep 19, 2024 | 07:46 PM
Lisa Dubs's Avatar
AudiAllTheWay, Marvel Mystery Oil is supposed to break down carbon and sludge in the system. So, the idea is, if the rings are stuck due to carbon build up, it might help. I'm not sure what the mechanic used when he de-carbed the head. It may have been the B-12 you mentioned. He didn't say. At any rate, this is a last ditch effort to improve the compression in the two cylinders that were low.
Old Sep 20, 2024 | 12:34 AM
alex_hobeanu's Avatar
These cars don't have a fuel pump relay so if you removed a relay then that relay is for something else. As long as it is authorized to start (key recognized by the car, transmission interlock ok), if the start button is pressed (or the key is pushed in), the starter will be energized. It doesn't matter if the coils are connected or not.
Old Sep 20, 2024 | 01:06 AM
jasonfire's Avatar
Very good idea mate.
Old Sep 20, 2024 | 09:31 AM
stash64's Avatar
Berryman B12 is what I have seen recommended for the piston soak procedure.
Old Sep 21, 2024 | 07:12 PM
jasonfire's Avatar
I have read somewhere in manual that AUDI suggets to use acetone to clean injectors, maybe it can be used to clean those stuck piston rings.
Old Sep 23, 2024 | 03:14 PM
Lisa Dubs's Avatar
I removed the fuse for the fuel pump. I also put it back in and tried it again. I will try jumping it in case the battery has gotten a little low (shouldn't be, but you never know). Not sure what else would keep it from turning over.
 Pouria Savadkouei
 Michael S. Palmer
nick-mafia
Q7 MK 1 Discussion
Jan 20, 2022 05:20 AM
scottndsky
Q5/SQ5 MKI (8R) Discussion
Jan 9, 2019 12:16 PM
popdemonic
Audi Original "S" Cars
30
Dec 3, 2008 08:30 PM
Riz3
Jun 2, 2007 09:34 AM
