06 A8L AFS Headlight Power Plug
Also have the AFS Defective warning is flashing. It's a separate issue but need to fix it since the front bumper cover is off. There again it may be wiring or motor. Strange that both quit working at the same time. I checked the fuse box, found one of the two fuses, designated AFS left and right, was burnt and one was not. I would think one would still work but doesn't.
Appreciate feedback on these issues from someone who has successfully fixed these problems.
I believe from the look of the plug he tried to pry it off with a screw driver. The lock tab is still there but has broken off the housing and just pulls out. The wires to the plug are brittle but still appear firmly attached. The insulation is fragile for sure. i have ordered a new 14 wire plug which comes with the pigtail. I will solder the spliced wires and seal with shrink.
I will tackle the AFS issue after I have the lights working.
Final note: Although the AFS isn't working, the lights are centered.
By the way, the front bumper cover came off without much trouble, reinstalling it was a PIMA !
New problem came up though. My battery went dead overnight, happened twice. The first time may be from having the doors open while I replaced all the window regulators that ruined the tint on the windows. I wonder if it happened again because I left the headlight switch on the Automatic setting instead of off. I wouldn't think so but I am still learning the quirks of my A8L.
Otherwise I have a drain, possibly from the radar detector being left on.
