2016 Q5 3.0T battery change
Old Sep 30, 2024 | 01:37 PM
visionguru's Avatar
Default 2016 Q5 3.0T battery change
When I tested the battery from the under-hood charging posts, battery tester said: "replace". So, I went to Costco and got an Interstate H8(49) AGM 1000CA, 900CCA, battery.
The battery was "Made in Germany", so it may very well be the same as OEM.
Well, the old battery was tested good when out of the car, still hold full charge, and 60% health, after 9 years.
Old Oct 1, 2024 | 08:24 AM
S4'ed's Avatar
If you used an "impedance" style of battery tester, it will not give accurate results if connected to the remote jumper posts in the engine compartment. This type of tester needs to be connected right at the battery.
Old Oct 1, 2024 | 09:09 AM
Bob Petruska's Avatar
25 Year Member
Correct, I have a Sonus tester and talked with them about this. Results depends on vehicle. Always test at the battery terminals.
Old Oct 2, 2024 | 06:04 AM
dret's Avatar
Greetings, I also have a 2016 3.0 T bought as new and I’m shocked on how long this AGM battery is lasting. I have 50k miles so it doesn’t get much use so I occasionally put it on a charger. I’ve replaced my wife’s standard lead acid battery twice and both vehicles are the same age.
thetoddjohnson
Q5/SQ5 MKII Discussion
Dec 20, 2023 05:43 PM
Andy de Groot
A6 (C7 Platform) Discussion
Sep 27, 2023 07:04 AM
brettfletcher79
Q7 MK 1 Discussion
Sep 15, 2021 08:00 AM
Jeff A3 3.2
Audi A3 / S3 / RS 3
Feb 1, 2011 06:50 AM
A4_THOR
Jan 13, 2004 11:39 AM
