Oil Temperature Sensor
Old Oct 10, 2024 | 09:54 AM
klouisdrk's Avatar
Default Oil Temperature Sensor
2006 A8L 4.2L engine. VCDS is giving me this code 16580 - Engine Oil Temp. Sensor (G8) P0196 - 004. However searching several Audi parts websites, nowhere am I finding a part number for an engine oil temp sensor. Also can find where it exist on the car. If anyone can shed some light on these two things, I am appreciative of the info.
Old Oct 10, 2024 | 11:31 AM
AEightSilver's Avatar
Isn't that the oil pressure switch 06A-919-081-J you are after?
Old Oct 11, 2024 | 05:24 AM
dvs_dave's Avatar
AudiWorld Wiseguy
Oil temp sensor is the sensor in the sump
Old Oct 11, 2024 | 06:07 PM
klouisdrk's Avatar
That may well be it. The description list "oil temp switch" as another name for this part number. Thank you, Do you know where it is on the car?
Old Oct 14, 2024 | 05:04 AM
PaulW's Avatar
Take the belly plan off and you'll see a wire and electrical connector that go to the bottom of the oil pan. That is most likely what you are looking for. You can always disconnect the electrical connector and see if the code changes, if it does, you have the right sensor.
Old Oct 14, 2024 | 05:44 AM
klouisdrk's Avatar
Thanks, but that is described as the "oil level sensor" but it's worth a try.
Old Oct 14, 2024 | 12:23 PM
dvs_dave's Avatar
AudiWorld Wiseguy
It is the oil level sensor, but there’s more to it than that. It’s actually a heated tip probe with temperature sensor, not a level sensor in the traditional sense.
The oil level is derived by the probe tip heating up, and then it measures how quickly the probe cools down once the heating is turned off. If it takes too long to cool down, it means the oil level is too low as the probe tip is above the oil level. If it cools down at the normal rate, it means the probe tip is submerged in oil and the level is ok.
It basically allows one very robust sensor with no moving parts to fulfill both roles. Oil temp and oil level. Smart.
Old Oct 15, 2024 | 05:04 AM
klouisdrk's Avatar
Thanks Dave, Much better explanation than I got from any of the Audi online parts dealers. They either weren't knowledgeable or they didn't respond.
 Pouria Savadkouei
 Michael S. Palmer
TheStrig
S4 (B9 Platform) Discussion
Mar 8, 2025 01:13 PM
Vortire
May 17, 2023 02:11 AM
DKPowers
Feb 8, 2022 09:47 AM
petek's imolavant
Sep 2, 2012 12:15 PM
bertible
Audi allroad
Apr 18, 2007 02:36 AM
