Constant battery drain
Wondering if it's feasible to check somehow with my meter to find the source of drain. Just not sure where to begin. Talked to local shop, and they thought they could have a few hours into it, before even finding the problem, turning into a pretty hefty bill. Any ideas appreciated!
Thanks,
Tim
How long did you run the car with the new battery? Enough to fully charge it? You should also code it in with VCDS to reset the battery energy management module and ensure optimal performance and charging profile.
There’s every chance that the car still thought it had a bad battery so it commanded the charging system to go full power for too long, overcharging and damaging the new battery.
A bad alarm siren battery is also a common cause of battery drain. The siren battery isn’t user replaceable. Needs a new unit.
I didn't run the car that long, as I figured the battery was pretty full when I got it. I've slow charged it, and disconnected from car holds fine. I'm trying to get in touch with another shop I've used in the past that's really good, so hopefully they can diagnose and correct it.
Thanks
