Air suspension/VAGCOM question
As you obviously have a leak in front, you’ll need to fix that asap or it’ll only get worse, and you’ll eventually end up burning out the compressor from overwork. The side that’s slightly lower is the side with the leak. The sway bar pulls the other side down with it which is why is looks like the whole front axle has collapsed.
But more importantly, you can use measuring blocks to see the relay position, the height of the shocks, the accumulator and system pressure, etc. It makes it much easier to troubleshoot when you start looking at those things. Look at the system or shock pressures along with relay position and compressor temperature. Then start the car and see what happens. Sometimes the compressor won't run until you are moving. Best of luck.
