Battery Charging
Old Oct 24, 2024 | 06:17 PM
maxandtara's Avatar
Default Battery Charging
For the A8 does Audi have any recommendation for battery charging? Either connected or disconnected?
Fact = VCDS procedure when re-calibrating the rear brakes (you are suppose to attach a battery charger)
I believe the only exception is the use of "old style" battery chargers.
The OEM battery of the A8 is an AGM battery. The only way to charge this battery is with the use of "modern battery chargers".
So if I charge the battery with an ODYSSEY battery charger, I should be okay?
Old Oct 25, 2024 | 04:48 AM
dvs_dave's Avatar
AudiWorld Wiseguy
Pretty sure the D3 doesn’t have an AGM from the factory. Standard flooded cell.
And you hookup a standard charger direct to the battery +ve, and the -ve to the jumper post.
Also, no particular need to have a battery charger hooked up to do the brake pads, unless you have a known weak battery. That’s just dealer procedure to eliminate any battery charge issues as techs may be working multiple jobs simultaneously and leave the car “on” unattended for a while.
Old Oct 25, 2024 | 08:39 AM
maxandtara's Avatar
Thanks Dave!
Old Nov 4, 2024 | 12:54 AM
maxandtara's Avatar
Dave,
Speaking of battery, I don't recall seeing any battery vent tubes. Are you familiar with the plumbing of these vent tubes ?
Old Nov 5, 2024 | 06:17 AM
dvs_dave's Avatar
AudiWorld Wiseguy
There definitely is one. Not sure on routing, but if yours is missing, I can’t imagine it being too much of a challenge to run a new one.
12 Cats
Jul 21, 2022 06:12 AM
Rudy84301
A4 (B8 Platform) Discussion
Feb 1, 2022 12:49 PM
Jeff A3 3.2
Audi A3 / S3 / RS 3
Feb 1, 2011 06:50 AM
Ex-PzKW Cdr
Audi allroad
Mar 24, 2008 01:27 PM
A4_THOR
Jan 13, 2004 11:39 AM
