A/C Nightmare
I’m at the mind that there is a break somewhere in my wiring or something faulty because it doesn’t appear either of these problems or getting any voltage and I want to know if there’s any thoughts you guys have or anyway I might go about locating Ware the breach and the wire is without having to completely disassemble the car and the wiring harness?
I didn’t think it’s important that I mention when I was changing the axle on the right hand side of the car my elbow pulled loose to ABS sensor wires and set off a bunch of lights and many of these faulty code readings below… I reconnected them, but they all remain
Please find below my latest code reading :
Car Scanner ELM OBD2
Version: 1.111.7/1.111.7/iOS
DTC report
Connection profile: Audi OBD-II / EOBDDate: 10/2/2024 5:53:01 PM
VIN: WA1LFAFP9EA096101
OBD-II
No DTC found.
19. CAN Gateway
No DTC found.
09. Onboard supply control unit09. Onboard supply control unit
DTCs: 5
01535 [0x05FF]
Submission of a control signal to the right-headlight-V49 corrector actuator motor; Control for servomotor headlight range control right-V49
Status: Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory
01316 [0x0524]
Brake control unit
Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
03020 [0x0BCC]
Local data bus 2
Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory
03608 [0x0E18]
Status: Pending fault present, Test conditions are met, Validated and stored in non volatile memory
02258 [0x08D2]
Garage door opener transmitter; Transmission unit garage door opener
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
02. Transmission control unit02. Transmission control unit
DTCs: 2
12464 [0x0030B0] Archive (inactive)
P170300: Limp home, control unit reset
Emergency running, control unit reset
Status: Test failed since last DTC clear
13856 [0x003620]
P188700: Vehicle Speed Signal wheel speed from brake control module, Implausible signal
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 255
Odometer: 191600 km
Date, time: 2024.09.26 13:22:20
Paramteric values: 20 96 28 F4 42 36 86 03 01 4E 21 04 4E F4 0C 0C 34 21 02 0C 0C 21 03 00 00 10 05 00 00 21 0E 00 21 0F 02 10 2D 80 1E 21 10 00 06 20 02 0006 10 1E 00 10 20 01 08 05 0A 10 2F 40 10 34 02 CA 10 3B FF 10 3A 00 00
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
03. ABS control unit
No DTC found.
01. Engine control unit01. Engine control unit
DTCs: 3
04698 [0x00125A]
U111300: Function limitation due to received malfunction value
U101700: ABS brake control module, Read out DTC
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 191600 km
Date, time: 2024.09.26 13:22:19
Engine RPM: 787 rpm
Calculated engine load value: 16.47 %
Vehicle speed: 0 mph
Engine coolant temperature: 194 ℉
Engine oil temperature: 105.8 ℉
Barometric pressure: 96 kPa
Klemme 30 voltage: 13
Paramteric values: 20 96 28 10 7A 03 11 BD 0D 96 13 38 05 12 16 03 9B 15 14 04 12 6E 30 F2 10 10 01 8A
04699 [0x00125B]
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 191600 km
Engine RPM: 787 rpm
10537 [0x002929] Archive (inactive)
P202600: EVAP Fuel Vapor Temperature Sensor Circuit Low Voltage
Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor, Circuit Low Voltage
04. Power steering04. Power steering
DTCs: 2
6628353 [0x652401]
B200049: Ctrl. module faulty
Fehler während Challenge&Response-Ebene 2
Status bits: 1
Priority: 1
Frequency: 1
Odometer: 190136 km
Date, time: 2024.09.05 00:06:54
Status: Test failed, Confirmed, Warning indicator requested
5258753 [0x503E01]
C10ACF0: Steering, End stops not learned
Lenkungsendanschläge nicht angelernt
Status bits: 1
Priority: 6
Frequency: 254
Unlearning index: 229
Odometer: 191600 km
Date, time: 2024.09.26 13:23:24
05. Authorization system for access and starting the engine
No DTC found.
08. Heater and climate08. Heater and climate
DTCs: 3
01592 [0x0638]
Air Pollution Sensor-G238; Air quality sensor-G238; Throttle valve control part-J338 implausible signal
Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
00256 [0x0100]
Refrigerant Pressure and Temperature Sensor-G395; Refrigerant pressure / temperature sender-G395; Air mass meter-G70 supply voltage
00457 [0x01C9]
On-board power supply control unit-J519; On-board power supply control unit J519
0D. Slide Door Left (VW TP2.0)
No DTC found.
15. SRS
No DTC found.
16. Steering column16. Steering column
DTCs: 1
01316 [0x0524]
Brake control unit
17. Dashboard
No DTC found.
2E. Mediaplayer 3 (VW TP2.0)
No DTC found.
36. Driver seat adjustment
No DTC found.
3C. Lane change assistant3C. Lane change assistant
DTCs: 1
730117 [0x0B2405]
C1115F0: Lane change assistance control module 2, Automatic calibration not possible
Control unit 2 for side assist - no basic setting/adpation
Status bits: 1
Priority: 3
Frequency: 3
Unlearning index: 226
Odometer: 191600 km
Date, time: 2024.09.26 13:23:18
42. Driver door electronic equipment
No DTC found.
44. Power steering44. Power steering
DTCs: 2
6628353 [0x652401]
Status bits: 1
Priority: 1
Frequency: 1
Odometer: 190136 km
5258753 [0x503E01]
Status bits: 1
Priority: 6
Frequency: 254
Odometer: 191600 km
46. Central comfort systems module (VW TP2.0)46. Central comfort systems module (VW TP2.0)
DTCs: 4
02907 [0x0B5B]
Sunroof control unit-J394; Roof blind control unit-J394
Status: Pending fault present, Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
01512 [0x05E8]
03073 [0x0C01]
Rear lid sender closed
03532 [0x0DCC]
47. Acoustic system47. Acoustic system
DTCs: 1
02247 [0x08C7]
Subwoofer-R148
Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
52. Front passenger door electronics
No DTC found.
53. Parking brake53. Parking brake
DTCs: 2
459776 [0x070400]
FC_SIGNAL_ESP_FR_RADGESCHW_ERROR_VALUE
Status bits: 1
Priority: 6
Frequency: 2
Odometer: 191600 km
Date, time: 2024.09.26 13:23:31
Engine RPM: 9251 rpm
Calculated engine load value: 0.00 %
Vehicle speed: 0.621371192237334 mph
Engine coolant temperature: 219.2 ℉
Engine oil temperature: -40 ℉
Barometric pressure: 5 kPa
Klemme 30 voltage: 0
463616 [0x071300] Archive (inactive)
FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 11
Odometer: 191730 km
Date, time: 2024.10.01 22:04:49
Engine RPM: 8366 rpm
Calculated engine load value: 100.00 %
Barometric pressure: 7 kPa
Status: Confirmed
56. Head unit (MMI) (VW TP2.0)56. Head unit (MMI) (VW TP2.0)
DTCs: 1
03157 [0x0C55] Archive (inactive)
Status: Validated and stored in non volatile memory
62. Rear left door electoronics (VW TP2.0)
No DTC found.
6D. Tailgate/Boot lid
No DTC found.
72. Rear right door electronics (VW TP2.0)
No DTC found.
77. Telephone
No DTC found.
78. Slide Door Right (VW TP2.0)
DTC report
OBD-II
No DTC found.
19. CAN Gateway
No DTC found.
DTCs: 5
01535 [0x05FF]
01316 [0x0524]
Brake control unit
03020 [0x0BCC]
Local data bus 2
03608 [0x0E18]
02258 [0x08D2]
DTCs: 2
13856 [0x003620]
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 191600 km
No DTC found.
DTCs: 3
04698 [0x00125A]
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 191600 km
Engine RPM: 787 rpm
04699 [0x00125B]
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 191600 km
Engine RPM: 787 rpm
DTCs: 2
6628353 [0x652401]
Status bits: 1
Priority: 1
Frequency: 1
Odometer: 190136 km
5258753 [0x503E01]
Status bits: 1
Priority: 6
Frequency: 254
Odometer: 191600 km
No DTC found.
DTCs: 3
01592 [0x0638]
00256 [0x0100]
00457 [0x01C9]
No DTC found.
15. SRS
No DTC found.
DTCs: 1
01316 [0x0524]
Brake control unit
17. Dashboard
No DTC found.
No DTC found.
No DTC found.
DTCs: 1
730117 [0x0B2405]
Status bits: 1
Priority: 3
Frequency: 3
Odometer: 191600 km
No DTC found.
DTCs: 2
6628353 [0x652401]
Status bits: 1
Priority: 1
Frequency: 1
Odometer: 190136 km
5258753 [0x503E01]
Status bits: 1
Priority: 6
Frequency: 254
Odometer: 191600 km
DTCs: 4
02907 [0x0B5B]
01512 [0x05E8]
03073 [0x0C01]
03532 [0x0DCC]
DTCs: 1
02247 [0x08C7]
Subwoofer-R148
No DTC found.
DTCs: 2
459776 [0x070400]
Status bits: 1
Priority: 6
Frequency: 2
Odometer: 191600 km
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 191730 km
Status: Confirmed
DTCs: 1
No DTC found.
No DTC found.
No DTC found.
77. Telephone
No DTC found.
