Valve Cover Bolt Access
A8Silver, I did warn you, what makes them hard to remove are that those protruding screws that keep the shield in place, will easily snag that heat shield as you pull them out.
What prevented you from pulling it out ?
If you remove the fender liner and the heat shield, it gives you all the space and leverage necessary, no special tools required. The difference of removing the heat shield is like the difference of night and day.
I recall posting a pic that shows that you can comfortable put both your hands through that open space once you remove the heat shield.
Bolt is welded on the chassis. The 3 nuts are like thin washers, I think I removed them with just my fingers.
Warning ! I repeat the difficult part heat shield removal is that it easily snags on those screws. (There is an overlap of heat shields that share that one bolt closer to the firewall)
Well for me we all complain about the tight confines when working on the A8's. I have removed so many more things in this car to access a particular part.
For me removing this part is well worth it, the extra work considering reward ratio (extra working space) is well worth it.
By this time, from the work done through the years, these heat shield should be pretty banged up. These are just glorified thick aluminum (embossed)
Getting generic ones and just custom cut them should reasonably be affordable.
For me if you are working near them and need some extra room, just tear them out, without fear, they are not budget busters to replace.
The pain in trying to keep them in one piece is not worth it.
