Installed repaired ABS module, new issues
Just got my module back from module master and installed it. Car lifted great and most every light that was on is off now. Sadly the ABS and traction control lights are still on and now the brake light (not parking brake) is constantly flashing.
Has anyone experienced this after fixing the ABS module?
It's throwing any codes so very confused.
Should I disconnect the battery for a while?
Drive it a while?
Or is it that it needs to be recoded or the recalibrated?
If recalibration how do I do that?
Or it could be that the repair somehow lost the existing programming. Its straightforward to do. If you have an old saved scan result with your original module, you should be able to get the coding to apply to the current module from that as well.
