Anyone with a good grasp of Kessy system layout ?
The VAGCOM says that the antenna in all 4 doors is not communicating. Then yesterday and today the system began functioning correctly, but only for one or two destinations and the accompanying lock/unlock cycle. Both days the system has worked on the first try after sitting locked over night.
What is the common link between the antennae that could produce that code, and which could randomly work or fail in such a fashion ?
From historical experience MMI and KESSY are the most common sources of gremlins of the A8.
These boards where built with no tolerance for moisture. The Kessy module underneath the driver's seat is easy enough to check.
I have not seen people replacing faulty components that communicate with the Kessy. If the issue is not the Kessy, that rabbit hole is deep.
) but you're pretty cool for a geezer (said as someone who has hung out with the Awdinut several times)...I don't think swapping a KESSY is a good idea because it interacts with all the protected modules, so one would have to reprogram either the KESSY to sync with them or all the modules! But that's IIRC, which CAN be a problem!
PS, the KESSY is under the carpet in the lowest possible water-retaining position in the car. Right when ya think these cars were wonderfully designed, ya discover THAT bit of planned obsolescence!!
PPS Agreed with Dart (MaxandTara) it is a deep rabbit hole!
