Damaged engine noise, what could it be? 4.2 TDI
Old Dec 18, 2024 | 12:26 AM
Daxment's Avatar
Default Damaged engine noise, what could it be? 4.2 TDI
Strange noises in the engine, could it be a damaged timing chain? The noise comes from the right cylinder head on the passenger side. The car starts, the engine runs smoothly without vibrations, but the only issue is the noise. What could be the cause?
No errors in the engine controller.
https://youtu.be/H7wiH9l9FQU?si=1wgs-93QBHJE_Xj2
Old Dec 18, 2024 | 12:39 AM
Daxment's Avatar
<iframe width="560" height="315" src="https://www.youtube.com/embed/H7wiH9l9FQU?si=j_0_RId4SWwwP8EM" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Old Dec 19, 2024 | 01:30 AM
Daxment's Avatar
Originally Posted by Herut
I had a similar issue with my 4.2 TDI, and it turned out to be a worn-out timing chain tensioner. If you're hearing noise from the passenger side cylinder head, that could be a clue. I also found some helpful insights from MJM Engines reviews, they are quite reliable for diagnostics. Hope you will figure it out and fix soon!
The noise is more noticeable on the right side, near the passenger side. However, it also spreads across the engine and can be heard from the rear of the engine as well. There are no error codes in the control unit, the engine runs smoothly, and it starts nicely on the first try. This happened suddenly. I turned the car off, and it stayed parked overnight. The next day, I started it, and this unexpected noise appeared. I also found a case where someone changed the oil, and after driving a certain distance, something similar happened. That's why I suspect it's something related to the timing system.
Old Dec 19, 2024 | 08:53 AM
Daxment's Avatar
New video of the engine running
Old Jul 16, 2025 | 03:45 PM
Billprevost's Avatar
Default The real Stereotomy
Did yoou figure out what this was? Mine is very similar. I've replaced all 8 ignition coils and plugs. I have two camshaft postion sensors on the way, should be here in a few days.
llllethal
Jan 10, 2024 09:09 AM
Suzanne Persyn
Feb 27, 2020 08:08 AM
SUPERSTARDJ01
Q7 MK 1 Discussion
Oct 12, 2019 03:59 PM
fiberworks
Oct 19, 2004 11:41 AM
