MMI select
Old Dec 21, 2024 | 04:41 PM
zen beer's Avatar
Default MMI select
I just got this one running from a no start condition due to a broken steering column lock. Now when trying to select anything with the MMI I can scroll to my hearts content, but when I push on the button to select nothing happens? Anyone familiar with this or heard of it before. No codes that I am seeing in VCDS that would indicate an issue.
2009 S8
Old Dec 22, 2024 | 09:08 AM
dvs_dave's Avatar
AudiWorld Wiseguy
Most likely a bad selector **** on the MMI control panel. Could just need cleaning, or it’s bad and a replacement control panel is needed.
Old Dec 22, 2024 | 12:30 PM
zen beer's Avatar
before I take the center console apart is that center button able to be cleaned? Most post I see are for the buttons around the MMI
Old Dec 22, 2024 | 01:22 PM
dvs_dave's Avatar
AudiWorld Wiseguy
As much as the buttons are. They’re all on the same board.
Old Dec 23, 2024 | 06:19 AM
zen beer's Avatar
If I need to replace does the MMI require vin coding? If so can it be done through VCDS or carprog without in circuit soldering(6pin eeprom)?
Old Dec 26, 2024 | 07:52 AM
dvs_dave's Avatar
AudiWorld Wiseguy
The MMI control panel is not VIN locked. Straight swap plug and play. Loads available used online. Just consider its a common failure item (because of where the cup holders are, they often get drinks spilled onto them) so make sure to buy from a reputable seller with good return policies.
Old Dec 30, 2024 | 04:12 PM
zen beer's Avatar
Thanks, 10 minutes later and I have button select again. Super simple and there are circuit boards available on amazon/ebay if you can't find a replacement.
zen beer
Oct 9, 2023 01:55 PM
leeelooo
Q7 MK 1 Discussion
9
Sep 20, 2022 08:16 AM
Donald Middleton
Oct 27, 2018 12:28 AM
automarine
Jan 7, 2018 06:41 PM
TRM04
Jul 29, 2016 09:26 PM
