air suspension O ring
Old Dec 31, 2024 | 03:20 PM
zen beer's Avatar
Default air suspension O ring
I read through a lot of the threads on suspension and decided to take mine apart before doing a rebuild. For those of you who think it might be an o ring here is what I found out that I didn't find on the forum.
pictures or it didn't happen.
A few things to note. My top nut was not 41mm it is a 42 or larger. I think this shock is a reman by Arnot as it has their name on the dust cover, but Conti sticker is still there. Also how the wire enters the shock is different. This being from an S8 I don't know if the design is different or not but it looks different from the other threads I have seen with an internal spacer?
I could have done this on the car, but it would have been difficult as had to completely remove the dust cover
I could have done this on the car, but it would have been difficult as had to completely remove the dust cover and I had to reuse the ear clamp.
rubber/plastic spacer?
broken oring forgot to take pictures before I tested it
Oring goes here to seal the bag
Oring goes here to seal the bag you can see the spacer more clearly
Arnot reman, probably
Conti at some point
Conti at some point
I looked all over for oring sizes and found a couple different references, none of which I could find easily. Ended up using Nitrile 63mmod 56mmID 3.5mm cs
Old Dec 31, 2024 | 10:27 PM
dvs_dave's Avatar
AudiWorld Wiseguy
Yup, that’s an Arnot reman. They use Continental air bags.
You should have contacted Arnot. They have a lifetime warranty.
Old Jan 1, 2025 | 04:10 AM
zen beer's Avatar
Doesn't look like that is the case anymore and isn't transferable since I am not the original owner. Dang, was hoping to use it on the other side....
Limited 2-Year Warranty
Arnott warrants its products against defects in materials or workmanship when used on private passenger cars and light trucks under normal operating conditions for two (2) years from date of purchase, provided the original purchaser owns the vehicle on which parts were originally installed.
Old Jan 1, 2025 | 04:18 AM
zen beer's Avatar
Oh almost forgot for those of you doing this the other piece of information I didn't find was removing the pins from the connector. You use the VAG mini pin removal tool and you have to use a pair of needle nose pliers to pull our the secondary lock (purple thing) first. It takes a bit of force but it is designed to pull out. To reassemble put the pins back in then reinsert the lock by pushing back in fairly hard till it seats.
Red wire is in position 1 in case you forgot to document
I am not sure any of this matters as I have been unable to find a rebuild kit here in the US.
Old Jan 2, 2025 | 03:28 PM
zen beer's Avatar
Well, slight update, the Oring is actually 50mm ID x 4mm cs I couldn't find one so picked up a standard US size from the local HW store as a test. It works, but it is also leaking from the control valve where it goes into the aluminum can. Guess I am going to pony up for an aftermarket as I can't find that part anywhere and am guessing it is OEM for Arnott.
Long story short, if you feel air coming out the bottom of the shock (by the dust cover it is probably an O ring at least on Arnott's and is super simple to fix. I did call them and there is still a limited lifetime warranty, but only for the original owner.
Old Jan 2, 2025 | 08:52 PM
the green amigo's Avatar
You can buy the bags on eBay, disassemble and reinstall on the original shock. Complete outer case with fittings, bag and orings.
Old Jan 2, 2025 | 08:57 PM
maxandtara's Avatar
Try
https://www.oringsandmore.com
I just did a quick look at metric fkm oring 90 black. There is one 49mm ID x 4mm cs $2.46
If if are patient enough to look around you may find what you want.
Give them a call, they may be able to help you out.
Yeah... I believe i did some research a while back. I collated info on all I could find about orings of the suspension based on available posts.
if you fill in the the info, I am sure this will help the next guy.
Do you have the dimensions of smaller oring?
btw Here is the info from other posts
Front suspension orings
Small oring
ID
Ltooz_a6_a8_q7 9.53 mm (⅜ inch)
Tstealth32 11 mm
CS
Tstealth32 2 mm
Ltooz_a6_a8_q7 3 mm (based on the image Louise posted. It looks shy of ⅛”)
1.57 mm to 2.38 mm (1/16 or 3/32 inch )
Large oring
ID
Tstealth32 57 mm (2-¼ inch)
Capbarbaruiva 64 mm (2-½ inch)
Ltooz_a6_a8_q7 67.8 mm 2.67 inches (2-⅝ inch)
CS
Tstealth32 3 mm
Capbarbaruiva 3 mm (based on uploaded picture of a worn oring).
Ltooz_a6_a8_q7 1.57 mm to 2.38 mm (1/16 or 3/32 inch )
Old Jan 3, 2025 | 05:51 PM
zen beer's Avatar
I haven't taken the shock completely apart due to it being an Arnott and the tools required are different. I have a set comping from Aerosus since I couldn't find a rebuild kit and the shock bag assembly looks way different from Arnott. Couldn't find anything good or bad about aerosus really but half the price of Arnott and maintains CDC figured I would take a shot...
Once I get those on the car I will tear into the Arnott's to see what the differences are and repair if I can to have a spare set. Will take measurements then of everything
 Pouria Savadkouei
 Michael S. Palmer
gbmarc
Mar 24, 2020 11:59 AM
audijim113
Nov 18, 2016 08:17 PM
x3noc
Q7 MK 1 Discussion
Mar 13, 2015 02:02 AM
12vWhat
Audi allroad
Mar 3, 2012 09:23 PM
AutoUnionQ7
Audi allroad
12
Jan 20, 2008 06:06 PM
