Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Vcds "Interface not found"
Old Jan 4, 2025 | 11:32 AM
ANASABDULIND's Avatar
Default Vcds "Interface not found"
Hi, trying to DIY the service interval on my Audi. All the research I did led me to the Ross tech hex v2 tool to do it properly.. downloaded the software form official website but when I plugin the tool to my car no options are available but "program options" and it only leads to "testing" which everytimes returns to interface not found .. tried the fixes on YouTube but didn't work any help is very welcome
Old Jan 4, 2025 | 04:14 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Well, VCDS only works with specific Windows versions/operating systems, so not all are compatible.
That said, the first time you use it you have to set it up within that 'test' menu screen to establish which port it will be using, and there are directions online or included with the dongle for specifically for this purpose of initializing it. Basically, it's a 'pairing function' between the hardware (dongle) and the software you downloaded. Once that is done... you do need to be connected to the internet, BTW, and it will attempt to verify/update the firmware version on the dongle. All of this occurs before you can actually use it to scan your car.
Start with the basics of ensuring compatibility with laptop, correct application/software version downloaded from website, etc., etc.
There are official Ross-Tech videos online to watch on how to set it up/use it, or you can go to their website for additional help.
One of the tricks-of-the-trade on laptops/computers is to turn it off for a minute (power cycling), then turn it back on again (reboot), which clears about 95% of connectivity and other issues related to the computer itself being the issue.
Old Jan 6, 2025 | 08:38 PM
-Wes-'s Avatar
I know this is a few days ago now, but I wanted to mention that mine is finicky about connecting, too. I have laptop that only has USB-C connections, and I need to use a C-to-A dongle with the cable on the Ross-Tech unit. I use mine in this order, with the car on, laptop on, and connected to internet:
1. Plug the C-to-A dongle into the computer.
2. Plug the Ross-Tech unit into the car. Wait for it to change colors (I don't recall now.... red then yellow, or maybe green?). It is no more than maybe ten seconds.
3. Plug the USB-A end of the Ross-Tech cable into the dongle.
I have consistent success in getting the program to recognize the unit with this method.
mikee30
Q5/SQ5 MKI (8R) Discussion
Nov 3, 2020 01:46 PM
SJGQ5
Dec 16, 2014 04:03 PM
lock
Nov 9, 2012 12:08 AM
gscotts
Jun 16, 2003 04:11 PM
Dale B
Feb 1, 1999 03:17 PM
