headlight wiring crumbeling
1. Are the lenses/ headlights the same between S8 and A8 with just different internals for the LED versus standard? (In case I screw up)
2. Anyone heard of a company making a pre built harness or am I building one from scratch?
Now for the fun part since I have them apart..
The car is black with black interior I was thinking of updating since I need to have body work done what is group think of going triple black and doing a chrome delete including headlights? Car is a 2009 S8
There is a post in audiworld where a guy upgraded his HID lights. To separate the lens from the housing is not as easy as you may think. This guy used his oven to help him pry the lens from the housing.
You need to think of the rewiring and the lens replacement as 2 different jobs.
I did some rewiring a while back, man it is not easy. There is a learning curve to de-pinning.
You may play around with this before you go all out on this headlight, or just do surgery on the wires.
Let us know what route you decided to take. Good luck!
If it was just the lenses I would polish them and coat with creacoat and be done. Only reason I am going this far is to get to all the wires as the LED part in near unobtanium from what I can tell and the wires would probably be in the same state.Anyone have a list or type of pins used so I can order before disassembly?
You know I have never seen my car with the bumper on so not sure, but looks like this No Reserve: 2009 Audi S8 for sale on BaT Auctions - sold for $15,500 on June 6, 2024 (Lot #149,646) | Bring a Trailer
Reason I went to this effort is that when I bought my S8 it had what appeared to be extremely thick PPF on the headlights. My detailer had never seen it that thick. I believe the stuff was Apex. He would not remove it. I removed it with a heat gun set on low and hours later the original lenses under that PPF were MINT. I think that stuff had been one the headlights since the car was new. So, it worked... just difficult to remove. So, I have more time to tinker with my spare stuff...
Note that the small harness for the HID assembly (all small black wires) crumbles as well and is harder to sleeve... especially around the motor.
(edit) one more thing... keep adhesive tape FAR away from the chromed plastic internal to the headlight. I tried masking tape trying to save the chrome... ya, chrome lifts right off the plastic. Treat the chromed plastic like its gold plated and you are good. BUT the plastic underneath is black... so if your intent is to remove the chrome shouldn't be too hard
I did take apart the HID assembly to see if I could have the reflector re-plated. Not many people do it as it requires specialized equipment - PVD or Physical Vapor Deposition.
TE - 1452128-1 and 2-964296-1 for the male pins
harness removed
no way this light would have worked
-The first two looked similar one was just smaller than the other. Your TE type.
- The 3rd type looked totally different from the TE type you mentioned.
After going through the process, do a post just the the pin replacement process. What tool was best for you while doing this project?
