Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2014 Q7 TDI DEF Leaking
Old Jan 10, 2025 | 12:43 PM
Cbat's Avatar
Default 2014 Q7 TDI DEF Leaking
My DEF heater connections are leaking around the wires. Does anyone know of a fix for this?
Old Jan 10, 2025 | 04:14 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
If you are pretty certain that's the only leak source, then look up the part schematic and see if you can order that heater insert part or just the seal for it.
When my '10 started leaking DEF onto ground it was dribbling out just behind the RR wheel, and Audi said it was cracked tank, but I never got to eyeball it for myself. Wasn't complaining though as they just swapped the whole assembly out under warranty, which is what dealerships do...swap entire assemblies out.
Old Jan 10, 2025 | 05:54 PM
Cbat's Avatar
Thank you for the response; The leak seems to be the rubber insert/plug the two harness wires run through. The DEF heater appears only to be available with the tank. I wish it were under warranty because it cost around $1500.
Old Jan 10, 2025 | 06:18 PM
Well, you could always pull the heater or entire assembly from a 'donor' car/junkyard/parts recycler, etc., or find one online via part # search. If you buy a new one, then it's gonna be expensive part simply because it is an emissions control device, in short supply as multi-vehicle TDI models use it, and semi-complex.
The other alternative is simply to tune your TDI to Stage 1 and simultaneously turn off that reductant system once it becomes either non-serviceable, or a problem for you.
kev_roy09
3.0TFSI Engine Discussion
Feb 24, 2025 01:46 PM
rs5and12e
Audi A5 / S5 / RS5 (B9)
May 16, 2023 05:21 AM
mcs
14
Sep 2, 2021 09:01 AM
richsnipe
1.8T Discussion
Sep 26, 2007 10:41 AM
ajp_984
Jun 7, 2003 08:41 AM
