2009 Audi Q7 3.6L - Not cranking
Found faults in the Control Module for Access and Start Control
00456 - Control Module for Access and Start Control (J518)
004 - No Signal/Communication - Intermittent
01176 - Key
Looks like this may be the dreaded issue with the steering wheel lock but how can I confirm its not the ignition module or something else?
Like always on a Q7, look up the specific fault codes it gives you, and review related threads on same topic that come up via that error code search, etc. There are plenty of videos online and archival threads on this and other websites that discuss this topic/error codes. Always ensure your battery is well charged and the key fob battery is fresh as well.
I have reset the error code and the only one coming back every time I turn the key is the 004 Key - no communication
also note that to do a scan I am either turning on the emergency lights and holding the brake pedal or jumping pin 1 and 16 on the odb
Follow the codes, and be sure to pay attention to the date/time stamps present on each code in VCDS, along with how many times the code has popped/auto-reset, etc. That error code history data can tell you which came first, the chicken or the egg...figuratively speaking, and that's important when you have competing fault codes.
