Posable turbocharger problems
Have a Audi q7 2008
start to get problem, when i drive up to hill with small rpms get lost of power, car go to limp mode, coil symbol start to flashing, when i stop turn off engine and start again, its going good, turbo working some time.
on VCDS i get this faults :
any idea, is turbo is gone and need to replace, or can be something else?
is its posable that its come up becouse of EGR or DPF?
Address 01: Engine Labels: 059-907-401-ASB.clb
Control Module Part Number: 4L0 910 401 T HW: 4L0 907 401
Component and/or Version: 3.0L V6TDI G000AG 0020
Software Coding: 0011775
Work Shop Code: WSC 31414 790 00001
VCID: 3365AACB5235610B0E-8066
2 Faults Found:
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 002 - Signal too High (Rich)
Freeze Frame:
Fault Status: 01110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 206984 km
Time Indication: 0
Date: 2007.05.16
Time: 14:37:49
Freeze Frame:
RPM: 2058 /min
Torque: 3.9 Nm
Speed: 105.3 km/h
Duty Cycle: 6.0 %
Duty Cycle: 17.9 %
(no units): 0.0
(no units): 16.0
000565 - Boost Pressure
P0235 - 001 - Regulation Range not Reached - MIL ON
Freeze Frame:
Fault Status: 11110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 207017 km
Time Indication: 0
Date: 2025.01.11
Time: 15:57:59
Freeze Frame:
RPM: 2142 /min
Torque: 300.3 Nm
Speed: 35.8 km/h
Absolute Pres.: 2305.2 mbar
Absolute Pres.: 1305.6 mbar
(no units): 0.0
Temperature: 6.3°C
Readiness: 0 2 0 0 0
Isn't it odd you've got an O2 sensor fault stuck on showing an occurrence date of 2007/05/16, but the recurrence counter matches exactly to the boost pressure code's reference data, and the mileage capture on the O2 sensor shows it occurred prior (206984 kilometers) to the boost pressure code @ 207017 kilometers...so the O2 sensor is popping off a fault code first.
You could have couple diff things going on since it's an older Q7, but most likely you got an intake air leak or vacuum leak that's causing it to run rich, or your O2 sensor is going out, which definitely happens. You can look at the live data in VCDS for the MAF sensor/fuel injectors balance, etc., but just start simple and go over your intake air system/vacuum lines, etc. If there are additional fault codes you didn't list, now's the time to do that.
16619/P0235/000565 - Ross-Tech Wiki
when i drive longer time in same rpms fault not coming up even going up the hill, when i start to accelerate and go back to low rpms, on hill fault coma back.
try to change Map sensor, check with VCDS charge pressure control, on basic settings on its show me the same what on off.(1020mbar).
had before problems with EGR but that fault codes disappear long time ago.
A highly typical vacuum leak to check for on these Q7s is located at the firewall, where the brake-booster vac line comes through firewall, and then immediately connects with the engine's vacuum line...be sure to check there. The plastic on brake booster side of connector (female side) tends to crack from the heat-cycling of the engine. Other symptoms of that specific vac-leak issue are low or soft/spongy brake pedal.
When my own '10 TDI, or our '15 TDI has gone into 'limp mode' prior, it's been related to either a failed exhaust sensor or a vacuum leak related issue, that is screwing things up, etc. The majority of time on ours has been a bad sensor issue, but vacuum leak related faults are a close second.
Your mileage may vary, of course, since there is so much we don't know about your TDI, but hello...have you ever prior replaced that O2 sensor that is coding? How long has it been on this car? That sensor is either going to be the root-cause, or its' throwing the rich mixture coding is just a related symptom of the underlying, up-stream root cause issue, etc., which would have to be an issue that could result in a rich fueling condition (too much fuel/too little air). Since it is the O2 sensor's job to fine-tune the fuel/air mixture...see where I'm going with this? You might also verify how many O2 sensors your car has and relative location, as if only one bank of cylinders is reading rich...
The turbo's fault code is telling you to check the air intake and vacuum hoses/lines for leaks, which jives with why you could get a fault code on that O2 sensor, but like you detailed, it only occurs when you are taking it into higher revs/more vacuum situations, etc., and doesn't give you an issue with steady, moderate throttle, etc. TDI engines make a lot of heat, so vacuum leaks (and failed plastic items around the engine) are quite common as these age.
Tuesday,14,January,2025,07:17:51:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.0.0 (x64)
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WAUZZZ4L88D031746 License Plate: OE57OZO FULL
Mileage: 207570km-128978mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 18 19 34 37 42 46 47 4F
52 55 56 57 61 62 67 6C 6D 6F 72 76 77
VIN: WAUZZZ4L88D031746 Mileage: 207570km-128978miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Part No SW: 4L0 910 401 T HW: 4L0 907 401
Component: 3.0L V6TDI G000AG 0020
Revision: --H05--- Serial number:
Coding: 0011775
Shop #: WSC 31414 790 00001
VINID: 9D196AAAA11C2085000C11C4187A9C0996
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 207517 km
Time Indication: 0
Date: 2025.01.13
Time: 04:29:36
Freeze Frame:
RPM: 2310 /min
Torque: 0.0 Nm
Speed: 118.7 km/h
Duty Cycle: 1.0 %
Duty Cycle: 17.9 %
(no units): 0.0
(no units): 16.0
P0235 - 001 - Regulation Range not Reached - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 207562 km
Time Indication: 0
Date: 2025.01.13
Time: 19:42:49
Freeze Frame:
RPM: 2310 /min
Torque: 397.8 Nm
Speed: 53.8 km/h
Absolute Pres.: 1968.6 mbar
Absolute Pres.: 1499.4 mbar
(no units): 0.0
Temperature: 4.5°C
001025 - EGR System
P0401 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 207563 km
Time Indication: 0
Date: 2025.01.13
Time: 19:44:57
Freeze Frame:
RPM: 1449 /min
Torque: 89.7 Nm
Speed: 41.4 km/h
Duty Cycle: 77.7 %
Duty Cycle: 20.9 %
(no units): 0.0
Duty Cycle: 14.6 %
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
Component: AL 750 6A 1000
Revision: 00H64000 Serial number:
Coding: 0000504
VCID: 04073917471B16B3E7-8050
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0103569
VCID: 295948A380F92BDBB4-807C
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500870560
Coding: 0000147
Shop #: WSC 00561 210 91540
VCID: 63C51A8BA255B18BBE-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 L HW: 4E0 035 729 A
Component: Interfacebox H43 4220
Revision: 00000000 Serial number: 387JY077560054
Coding: 0002002
VCID: 3169A0C3A829531B7C-8064
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029ÿ
Subsystem 4 - Serial number: 010029ÿ
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Mileage: 207331 km
Time Indication: 0
Date: 2025.01.12
Time: 23:44:46
Address 08: Auto HVAC Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 B HW: 4L0 820 043 L
Component: KLIMABETAETIGUNGH07 0030
Revision: 00---013 Serial number: 00000000137454
Coding: 0001046
Shop #: WSC 00070 000 00000
VCID: 23455A8BE2D5F18BFE-8076
3 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 3
Reset counter: 54
Mileage: 207331 km
Time Indication: 0
Date: 2025.01.13
Time: 01:57:16
Freeze Frame:
Temperature: 13.0°C
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 207578 km
Time Indication: 0
Date: 2025.01.14
Time: 07:11:13
Freeze Frame:
Temperature: 40.0°C
Temperature: 6.0°C
Load: 0.0 %
Temperature: -55.0°C
RPM: 880 /min
Absolute Pres.: 1.0 bar
Current: 0.005 A
Temperature: 2.0°C
01087 - Basic Setting Not Performed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 110253 km
Time Indication: 0
Date: 2007.05.16
Time: 17:10:26
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0013121
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00022806
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H45 0350
Revision: 00045006 Serial number: AUZ5ZBG1238579
Shop #: WSC 00000 000 00000
VCID: 1D316C73C4B1C77BC8-8048
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V7600250
Coding: 0000001
VCID: 24475997E7DBF6B387-8070
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH42 0230
Revision: 03H42000 Serial number: 00399D03NNWT
Coding: 0014129
VCID: 2E53BBBFB9174CE361-807A
Subsystem 1 - Serial number: 6332QSME42323A537
Subsystem 2 - Serial number: 6342QSME42317A39F
Subsystem 3 - Serial number: 6352QSME3F134B27N
Subsystem 4 - Serial number: 6362QSME3B23401BD
Subsystem 5 - Serial number: 63734SME3E49173DC
Subsystem 6 - Serial number: 63834SME3E4B0B3DI
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025072790279
Coding: 0102142
VCID: 275D4E9B96ED1DABA2-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 981 B
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 74154XFA7
Coding: 3681458
Shop #: WSC 80093 222 69422
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B07A1081F6
Coding: F55BFE7F307E0200
VCID: 2D51BCB3B41137FB58-8078
2 Faults Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Mileage: 207331 km
Time Indication: 0
Date: 2025.01.12
Time: 23:44:48
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 51
Mileage: 207331 km
Time Indication: 0
Date: 2025.01.12
Time: 23:45:46
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
Shop #: WSC 33707 001 1048576
VCID: 2A5BB7AF85FF20C3BD-807E
4 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 11101001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 54
Mileage: 207562 km
Time Indication: 0
Date: 2025.01.13
Time: 19:40:59
Freeze Frame:
Error Code: 77
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 168
Mileage: 207390 km
Time Indication: 0
Date: 2025.01.13
Time: 02:46:48
Freeze Frame:
Error Code: 68
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 168
Mileage: 207462 km
Time Indication: 0
Date: 2025.01.13
Time: 04:00:16
Freeze Frame:
Error Code: 78
01583 - Leak in System Detected
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 54
Mileage: 207578 km
Time Indication: 0
Date: 2025.01.14
Time: 07:01:48
Freeze Frame:
Error Code: 70
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 M
Component: MNS ECE H50 1030
Revision: 00000000 Serial number: 399J5077589243
Shop #: WSC 00561 210 84714
VCID: 3E738BFF6977BC63F1-806A
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00-00000
Coding: 0002651
VCID: 2F6DA6BBBE1D45EB6A-807A
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H07 0050
Revision: 0050 --- Serial number: 01074485770000
Coding: 7610619
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
1 Fault Found:
02957 - Lamp in Trunk/Hatch Lid; Right
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 62
Reset counter: 54
Mileage: 206775 km
Time Indication: 0
Date: 2025.01.08
Time: 17:48:47
Freeze Frame:
Bin. Bits: 000 010
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4L0 910 223 H HW: 4L0 035 223 C
Component: DSP-AU716-RD H07 0250
Revision: S0600000
Coding: 030100
VCID: 295948A340F92BDBB4-807C
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000061479
Coding: 0011101
VCID: 5EB32B7F89379C6391-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00-00000
Coding: 0002651
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000022
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388J.077653008
Coding: 0000001
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 C HW: 4E0 919 148
Component: R0078 TVhybridTuner 0400
Revision: R0H06000 Serial number: 76300800851801
Coding: 0000303
1 Fault Found:
00863 - Antenna 1 for TV (R55)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Mileage: 207331 km
Time Indication: 0
Date: 2025.01.12
Time: 23:44:48
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4L0 910 181 A HW: 4L0 915 181
Component: J0644 BEM H12 0690
Revision: -------- Serial number: 00000000031395
Shop #: WSC 00561 210 91481
VCID: 25414493ECE10FBB90-8070
Subsystem 1 - Part No: 000 915 105 CE
Component: von JCB 270430U1HA
Coding: 30303039313531303543454A434232373034333055314841
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0002058
1 Fault Found:
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 51
Mileage: 207331 km
Time Indication: 0
Date: 2025.01.12
Time: 23:44:47
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000709250072
Shop #: WSC 12336 024 394758
VCID: 366393DF4147742329-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7X41NH
Coding: 1021001
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H28 0290
Revision: --H28001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD771B74F8BFEF30F-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD30.04.09--H28001001B0257ÿ
Subsystem 4 - Serial number: 1B0257ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003180082-----
Coding: 0003587
VCID: 2643439F91E704A399-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE16_SKB09H10 0200
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE16_SKB09H10 0200
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE16_SKB09H10 0200
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0150
Coding: 0002058
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 51
Mileage: 207331 km
Time Indication: 0
Date: 2025.01.12
Time: 23:44:47
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06340728501364
Coding: 0221146
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:46)--------------------------
