Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2014 Q7 TDI Heater Core Flush
Old Jan 15, 2025 | 03:36 PM
automan23's Avatar
Default 2014 Q7 TDI Heater Core Flush
Hi All! I have a 2014 Audi Q7 TDI with the front heater not working. All signs point to the front heater core being blocked. Just trying to figure out if it's worth replacing the whole heater core or if there is an easier way to just flush it out.
Thank you!
Old Jan 15, 2025 | 05:53 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Have you verified that the blend door is working with VCDS?
Old Jan 15, 2025 | 06:09 PM
automan23's Avatar
I have not tried that yet. Is there a reason you think it’s the blend doors and not the heater core?
Old Jan 15, 2025 | 06:32 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
This car holds lots of surprises for the uninitiated. Getting no heat output from either the front or rear HVAC blower systems doesn't mean a heater core is bad, though many jump to that conclusion. Look up 'heater core failure symptoms' online.
You always begin troubleshooting via VAGCOM full diagnostic scan of a Q7, as often that will tell you something about most problems you could have on this car. There's just so many electronics and feedback loops/sensors/actuators/coolant pumps on a Q7.
Then there are diagnostic procedures/test sequences provided in VCDS to help you identify that everything is working correctly (or not). The blend door inside the HVAC moves/controls the temperature you get, so if it is stuck or the actuator is stripped/bad on that door, then you not gonna get heat. There's other things to check/verify as well, starting with coolant reservoir level/coolant condition, etc.
There's just a lot more going on with the Q7 than most other vehicles beneath the surface, which is why you need an advanced/highly capable diagnostic scan tool like VCDS. You always want to start with the easy stuff/checks first...the low-hanging fruit, as it were.
WILLIE70
A4 (B7 Platform) Discussion
Jan 4, 2018 02:47 PM
Brdman*
Audi Original "S" Cars
May 11, 2006 07:24 PM
madeamistake
Sep 12, 2005 07:17 PM
yamahapro361
Mar 4, 2003 04:52 PM
ultrasparq
Nov 15, 2002 09:13 AM
