Rocker Moldings
FWIW: I found a similar inquiry on the 4M Q7 model, and the manual pages posted in that thread showed it uses double-sided adhesive tape across the top, then has locating pins beneath. Removal process stated to use a heat gun to warm up the taped area at top of the trim piece and then use trim tools to pry/lever it away from the door panel, then removal of panel is straight down, etc. Again, that's for the 4M Q7, but they likely didn't change how those lower door panel mouldings go on.
Here's link for reference to that 4M chassis Q7 thread: https://www.audiworld.com/forums/q7-...moval-3075138/
