A8 D3 oil retention valves theory
Sound clip of the horrible rattle:
https://youtu.be/DSlblqZLrq8?si=jjw2hnRM4AIxWb3G
So after some more research I tried to build up oil pressure by disabling ignition. When starting the car after first building up oil pressure for 10 seconds, there is no rattle at all and the engine sounds just fine.
Is my conclusion correct when this makes me believe it is the oil retention valves? In theory if the rattle is gone with oil pressure and the rattle is always there when there's no pressure (because all oil leaked back), I feel like the tensioners and guides themselves are not the issues.
Curious to your thoughts. I'm down to take out the engine for the guides, but only if really needed. I'd much rather do the retention valves if my theory is correct.
Thanks
At startup there is some rattle in these cars, especially after they sit for a while. Starting oil pressure is a factor for sure.
There are 2 schools of thought:
- The noise bothers me and is loud enough to cause me to do repairs (and I have the funds to do it)
- Oil check valves
- Cam tensioners (anecdotally last till around 220k km)
- I have a noise but will wait for the car to throw codes before taking action
- Trust the car to tell you when it needs to be fixed
- Oil check valves
As for those 2 points: the noise on startup is definitely horrible, did you see the youtube video I added in my first post? I feel like if I don't do something, it will grenade itself eventually. The car has 199k km so 123k miles and has always been taken good care of.
The gasket for the valley pan cover is very one off, even when I bought it over a decade ago. It was dealer only back then and hard to get locally when I needed it. Don't recall on check valves, but for most non- Audi deep dive enthusiasts, it is a little known or even understood part. Coolant temp sensor and intake gasket set (Reinz etc.) easy to find.
Quick update: I plugged in a fused on/off switch in the fuse #30 (30A fuse for ignitioncoils) on the passenger side which controls ignition. While I wait on the parts, I've noticed that whenever I turn off ignition in the morning and crank the car for ~10 seconds to build up oil pressure, the rattle is completely gone if I then start the car. This at least allows me to not break the car while waiting on parts. Maybe this will help someone who finds this topic in the future :-)
