When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
i have a 2009 a8 d3, by mistake i added steering fluid is stead of brake fluid. Tried to bleed with brake bleeder fluid pump nothing coming out of the bleeder. when i pump the pedal no presure build at all.
Pumping the pedal was probably a mistake. If it was just in the reservoir you could have possibly sucked most of out out because its a lighter fluid and would have floated on top. Now its all in your system. The PS fluid could play havoc with the rubber bits in the system and they may fail later. The longer that PS fluid is in the system the worse it will get. You can try to flush it out a few times using a power bleeder and hope for the best. Better yet would be to disconnect both ends of each line and try to clean them with air, etc. Messy situation you have gotten into. Brakes are not something to play around with as your life depends on it.
Good luck.
removed each line from abs blowed with air to each wheel, blowed each line from deposit to abs.
Blowed and aired each hole, added new fluid but i dont see liquid going from deposit to abs.even with bleeding pump at 3bar. (goes not pass thru from pump). Removed master cylinder and when i manual press the shaft only 3 of 4 holes i feel the air and the vacum. the 4th does nothing.
