Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Adblue problems
Old Jan 30, 2025 | 06:27 AM
marcT's Avatar
Default Adblue problems
Hi, I’m new to Audi’s and diesels! First refill and after 20 mins I get engine light! Read the codes and it’s p207f ( reductant quality performance)
and p20F4 ( reductant consumption to low)
I realized after I’ve filled it the fluid I used was not isolated 22241 rated! I’m thinking I should drain the tanks but trying to find if there’s a drain or do I need to drop the lower tank to do this? I can’t find anything online for the q7. I’ve only found touregs and there’s looks to be different set up
Old Jan 30, 2025 | 02:48 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
That's really interesting, but there have been other TDI owners posted about getting codes after filling with lesser quality/purity, generic versions of the DEF reductant fluid. They like the good stuff. Also, DEF has a short shelf life, so that's a factor to consider also, and you never buy DEF with crusty deposits on it.
I stick to using the name brand (Peak Blue DEF) stuff which is pretty darn cheap at approx $13 for 2.5 Gal jug at Sam's Club, etc. Tractor Supply has it for $17/jug, etc., and pricing on DEF will vary quite widely depending on the selling outlet. This Peak branded Blue DEF has incorporated a backpressure relief valve that makes it super fast & clean to add DEF to this TDI's tanks...no gurgling or spitting air bubbles at all. Highly recommended.
Here's a related thread: https://forums.tdiclub.com/index.php...v-tank.526063/
thegetawaycar
11
Mar 9, 2015 11:56 AM
MCPaudiTT - DEFCON 1
11
Mar 1, 2007 07:42 PM
d1rt [A4 Pröjekt]
Nov 30, 2006 02:38 PM
shell27502
Audi 100 / A6 (C4 Platform)
Jan 30, 2005 03:39 PM
BorntoBill
Jan 3, 2002 05:49 AM
