Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 transmission adaptation
Old Jan 30, 2025 | 01:06 PM
Raj800's Avatar
Default Q7 transmission adaptation
Hi fellows does anyone know how to do the transmission adaptation or clutch recalibration on Q7 2010 4.2 diesel using VCDS?
Old Jan 30, 2025 | 02:28 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
The internet can answer basic questions without any context...you just have to search.
One of the best and simplest things you can do on an older Audi Q7 is to recalibrate the drive-by-wire throttle pedal and clear the transmissions learning memory, etc. This doesn't require a scan tool; just following a simple procedure in car using throttle pedal and ignition key, etc. If you shared more....
Here's a link to read: https://www.youcanic.com/audi-transm...set-procedure/
Old Jan 30, 2025 | 02:58 PM
Raj800's Avatar
thanks for the reply mate just had TCM fuse blown and after that there is thud noise/jerk while putting into D R AND P it drives fine assuming needs calibration as it’s might be out
Old Jan 30, 2025 | 03:04 PM
Via VCDS, you can go to Transmission module, then review the adaptations and basic settings available. In most cases you'll have to use the security access button before you'll be able to use specific adaptations or basic settings options, but it'll let you look at them first just to see what's there.
If you haven't used the VCDS for anything like this prior, suggest you watch a video online of doing adaptations using VCDS, etc. If you do reset/adapt your tranny, then there's a learning drive cycle that follows that reset to allow the car to relearn the correct engagement of clutch packs, etc., and it's not about going fast or pedal to the metal (which is silly in a TDI anyhow), so read up on it/do your research.
Old Jan 31, 2025 | 01:34 PM
jbgilbank's Avatar
Yeah, adapting gear suppression, so that the actual gear number your using shows rather than D!
Best mod ever, especially for towing and actually should just be common sense to come that way from the factory!
Engineereric
VAG-COM Discussion
Aug 25, 2022 09:31 PM
q7seeker
Q7 MK 1 Discussion
Aug 9, 2022 08:43 AM
RS3R_X
Audi A3 / S3 / RS 3 MKII
15
Jul 28, 2020 03:52 PM
Bazzy
Jul 15, 2007 06:02 AM
shuto
May 23, 2001 02:34 PM
