Using 3.0t for Towing and Recovery?
I seem to have the towing package on my 2015, and I have the equipment for recovery from my last vehicle (recovery strap, D-hooks, hitch pins, all that fun stuff). Tires currently seem to be great in the snow, but I just genuinely don't know how capable it'd be.
Any suggestions/advice/personal experience is welcome! Thank you!
I use a kinetic recovery rope (1"x30') along with D-rings, soft shackles, an 8' "tree saver" strap (great for the under-car portion of connecting to the stuck vehicle in order to protect the more sensitive parts of the gear, like the rope), tire chains for all four corners, and a pair of tow hooks connected to 8' of heavy chain that I use to grab the front A arms on low-slung vehicles for quick purchase. Of course, I rarely use all of this gear during one recovery, but with all this gear, it is even more rare that there is a stuck vehicle recovery I cannot perform.
I just did ten recoveries two weeks ago (unseasonable weather with wicked ice that caused all sorts of havoc), and my son made some quick recordings of a few. I keep meaning to throw together a quick montage video, but I have yet to do so.
Last weekend, I was using spikes on my boots just to enable walking. Recovering without chains would have been a huge risk. I did two of the recoveries without chains:
1. Friday. Side road, road was not yet saturated, so traction was low, but present. F350, fully chained, 8' plow blade. Stuck due to pushing too far off the side of the road and becoming high-centered with one rear tire about 2' into the air. I used the kinetic rope, receiver to receiver, pulled uphill with stuck vehicle in reverse. One pull, truck was free.
2. Monday. Driveway, road was ice-covered snowpack, but with a little gravel sprinkled over (very little!). Access road was about a half mile, sheer ice, no gravel. I could barely maintain directional control on the access road. It was very sketchy. Once I made it to the driveway, I had enough traction that I could recover the stuck vehicle (I was pointed down hill this time), but it really whipped me around when I reached the end of the rope, and I had to struggle to keep my Q7 oriented. I probably should have used chains on this one, but I was being stubborn due to time constraints.
The chains I have for mine, all four corners, are "Laclede Alpine Sport Light Truck Tire Chains - 2326," purchased in 2017 from O'Reilly Auto Parts, and they work great! I use additional tighteners (10" EDPM heavy duty bungies w/ S-hooks, two per wheel) when I am using them for anything more than just a single recovery (i.e., get to site, install chains, recover vehicle, remove chains) as they help ensure that everything stays nice and snug while taking much of the stress off the built-in tightener.
The key element is just to give it a decent tug sufficient to get it unstuck. To do this on any slick surface/off-road you need to turn off your ESC/stability control button (next to the emergency flasher button below MMI screen), as this allows the AWD system to give maximum grip from the get-go.
