Deleting EGR and DPF
If you bought a Malone/Tunezilla tune, or are shopping it, be aware they offer the original TCU 'factory tune' (rollback from dieselgate TCU tune) for free w/ECU tune purchase, and you definitely want this.
You don't mention the mileage on your '14, but the Bosch CP4 HPFP (High Pressure Fuel Pump) is mounted at the extreme rear of the engine valley on the Gen 2 TDI motor you got in there, and so if yours has never been replaced prior, that's also worth considering if your goal is to 'bulletproof' your TDI for the foreseeable future. Things get real painful and expensive if your HPFP shreds itself internally, contaminating the entire fuel system, and there are recently active threads on here related the HPFP failing if you want to check those out.
