Found my coolant leak
Mines got a pinhole leak in the radiator core, but it's a very slow leak. I'm getting ready to swap that bugger out and possibly some other old, beat-up heat exchangers while I'm in there...jolly good fun.
Thank you , if you have some time, would you be able to take a photo and identify the bleed screw you are referring to?
edit. I ran down the part number 4L0122447D and that part retails around $580-$600 for a hose online. When I called the local dealer, they had it for $750. I could probably cobble something together for a whole lot less. I do have a fidelity warranty with a $500 deductible so I guess I’ll suck it up and bring it in and have it done.
Does that seem logical?
If it's going into the shop, then get some good work done for your deductible. The fortunate thing is the policy excludes the the coolant hoses however, since this one has a metal and plastic parts, the representative said it should be covered if it was just premature failure. So I will just suck it up for the $500 deductible and keep my fingers crossed that it is. I’m still surprised that they would have such an expensive part for a coolant line. Also I find it strange that it is leaking from the plastic or metal portion.
