'14 Q7 3.0T Acceleration Issue
You do wanna watch the DCR (Different Car Review Audi Q7) for this 4L Chassis to learn about the known issues on both the chassis and for your specific engine; one key takeaway is then need to change your oil at least every 6500 miles if not sooner...don't go by what Audi publishes. Likewise, none of the 'normal maintenance' a car requires on the driveline has ever been done on your used Q7, unless you've got physical receipts for it from a third party shop...Audi doesn't change those lubricants, ever, and wrote them out of the maintenance schedule. You don't have a ton of miles on it, so just put that on your radar for something you should do sooner (lubricants in the front/rear diffs, transfer case, transmission fluid/filter service) rather than later.
Do the fly-by-wire throttle calibration too...it takes literally less than 30 seconds...no tools needed ; that one is usually a very impressive jump in throttle response off idle...gets the lag out.
